Question about Bosch Dryers
Heats spins but doesnt dry. its clean and lint free there is no exterior vent on it bosch axxis v20-ul thx
    President:
  • 3,074 Answers
If you have heat, then it's an airflow issue as inside your dryer you have several thermostats, one is called the high limit thermostat, when the dryer can not vent properly, the heat builds up in the dryer and this thermostat cuts off the heating element for safety reasons, and the heat may not come back on for 20 minutes, I understand there is no exterior vent but the dryer does vent air. More then likely once you take the dryer apart and clean the lint out of the inside it will run correctly. Hope this helps Tim
Posted on Mar 12, 2011
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis dryer - lint filter indicator lights up
Make sure the exhaust vent duct is clean all the way to the outlet.
Nov 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dyer will not turn on. I have cleaned the heat sensors, the lights go on, it is not over loaded..any thoughts
check the angle on the vent hose on the back of the machine and the vent flap hoodie thing outside also the vent hose should not exceed 11 feet. I had this problem and replaced the springy plastic covered vent hose with a rigid aluminum one and still have to check from time to time to make shore the hose is clear where it attaches to the machine. The lint from the extreme spin on the axxis washer is very fine and slightly damp it binds like paper mache.
Sep 29, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have an axxis not drying and code F:03 comes up
Most likely your wall vent is restricted. Unhook dryer from wall vent and pull away from wall. If you don't get code your wall vent needs to be cleaned.
If unit still gives code sensor is either bad or theres a restrictions inside machine, likely in the blower wheel hosing. Air flow when running should be strong coming out of vent. many times strength of a blow dryer.
Jul 18, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
145 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
