Question about Lakewood 007 Floor / Box Fan
How do i open my lakewood floor fan in order to clean it? it is filthy!!!
SOURCE: How do you clean Patton Floor fan?
Hello, I think there are some screws secured to the back of the motor. Loosen them, and the grille will come right off!
Posted on Mar 08, 2007
bigg t
  • 640 Answers
SOURCE: lakewood floor fan
most likley the set screw that secures the blade to the motor is loose.
Posted on Aug 01, 2007
  • 25 Answers
SOURCE: Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Posted on Apr 16, 2009
konzzz
  • 255 Answers
SOURCE: need help with fixing my lakewood floor fan.
try cleaning it and put oil especially at the base of the shaft.then try wiggling the shaft for bushing tolerance.if you feel the shaft wiggles to wide, then you'll need to replace the bushing and the shaft.but before anything else check the thermal fuse.it is found on the motor itself or try to borrow a tester with resistance measurement to check for continuity of the winding by connecting the probes with the plug, one each terminal.then turn the fan on.the pointer should move if its ok, unless burn out.if not.then the thermal fuse blow-out.
Posted on May 28, 2009
  • 109 Answers
SOURCE: Need to rewire Lakewood Fan
wires should be color coded. You can go to the hardware store and pick up some crimp connectors
Posted on Jul 07, 2009
How can I clean a Lakewood fan, mine is so filthy and I cannot get in to clean. My husband says it does not come apart.
ok here is what I found....there should be screws on the outside rim where the two fan grates meet....then dust the innerds with a leaf blower or a rag, then use brake cleaner spray to soften the greasy dirt that formed, and again a rag to wipe away any residue....hope this works, it did for me
Oct 25, 2013 | Lakewood HV-18 Floor / Box Fan
Can I order new "feet" for Lakewood box fans
I searched for your solution. This is the closest I can find. This is customer service for Lakewood.
https://secure.jardenstore.com/ContactUs.aspx
Another solution if the above does not work. You could make a couple of feet from some wood as well.
Feb 06, 2011 | Lakewood 101 Floor / Box Fan
Is this fan capable of being opened, because it has become dirty and I would like to clean it. Thank you
You can for sure open it and clean it ... use Proper Tools and Protective equipments . Unplug Supply wires before opening
Please Rate My answer well and Support me !!!
Nov 22, 2010 | Lakewood LAKWC1600 Floor / Box Fan
How do I clean the Lakewood Tower Fan LWTF-42/RC-DLX. How can I open it to clean the blades
Open the grills and use a long stem tipped with cloth dipped in kerosene to lightly clean the dust. Then use a similar arrangement of dry cloth wound on it to wipe clean the moist dirt. Repeat the process and you will have a clean blade. Use a jet air blower to assist you , use face mask and do it out in the open.
Helpful ?
Aug 20, 2010 | Lakewood 007 Floor / Box Fan
How do I clean the Lakewood tower fan
take apart the parts that come off and wipe them!
Dec 28, 2009 | Lakewood 007 Floor / Box Fan
Need help with fixing my lakewood floor fan.
May 28, 2009 | Lakewood HV 18-c Floor / Box Fan
Lakewood 200I Floor / Box Fan
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
May 27, 2007 | Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood 007 Floor / Box Fan Logo
637 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
