Question about Zanussi ZBM799X Electric Single Oven
Oven sometimes works ok other times takes twice as long to cook . Think it may be thermostat .I have no experience of repairing ovens Is it difficult to change thermostat
    Scholar:
  • 195 Answers
Sometimes they are hard to get to, looking at this picture i would think the panel has a screw or two on it that have to be removed , and always remove the power first, the thermostat has a capilery that goes into the oven , it is kind of like a long small tube that has a larger tube at the end of it , the end is what feels the heat so this long hose like tube will have to be sneaked back into where you took the old one out of. you must be very careful with the new one or you will be buying more of them if you get back to me Model, make, serial number i will locate one for you to buy ,, also temp range on the one you now have in the oven you can find this by looking a the knob temps ...Frank
Posted on Dec 10, 2011
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
During cooking the oven goes off. There is often a lot of water/steam present. Sometimes after a while it comes back on?
It could be that the overheat thermostat is kicking in, albeit earlier than it should do. Have you checked to see that the oven thermostat is working correctly and is not heating the oven up too much ( does the neon go off and on) and is the oven cooling fan running ok in the background. If these two appear to be ok, then you may need to replace the overheat thermostat.
(The oven cooling fan should remain on for about 5 to 10 mins after either oven or grill has been used. If this isn't happening or it is not running correctly then that is why the overheat device is shutting the oven off). As a thought, are the top oven and grill working ok? if they are, then it narrows it down to either the oven thermostat or the overheat sensor.
Nov 19, 2010 | Stoves 720EF Electric Double Oven
My oven takes ages to cook things am i missing
We had this problem; Your thermostat is probably broken. To test this theory, buy an oven thermometer and test how accurate the oven is. My bet is you will find this to be off. Fix it now, otherwise, it might lead to other issues.
Mar 31, 2010 | New World G90m Gas Double Oven
Oven will over cook sometimes and other times it will under cook
the only thing that will do that is a wonky oven thermostat. replace it
Oct 18, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven overheating
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
Sep 20, 2009 | Fisher and Paykel AeroTech - OS302M...
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Lang Oven EHS-PP
WB, Your thermostat is shot and must be replaced. The most difficult part of this job is locating one to replace it with. Have the complete Model and Serial number handy... First, try locally. Call a local Commercial Kitchen repair/parts house. Surely theres one nearby, they work on all McDonalds, Wendy's, Restaraunts, etc... cooking equipment. Second, contact the manufacturer; Star Manufacturing International, Inc. 10 Sunnen Drive St. Louis, MO 63143-3800 Phone (314) 781-2777 (800) 264-7827 Fax (800) 264-6666 After you have it, SHUT OFF THE POWER AT THE BREAKER!!! Now try to turn the unit on to VERIFY you have no power. Then remove the t'stat knob. Now remove the screws holding the control panel in place. Tilt the control panel out toward you. Now you can see the t'stat and see how the sensor bulb is routed. (HINT: Take a piece of paper and draw the back side of the t'stat's wire connection locations and wire colors/numbers, BEFORE removing anything.) Remove the wires and the t'stat and route/wire the new one the same way. Another tip; Be extremely careful with the sensor bulbs capillary tube (the small tube connecting the bulb to the t'stat). NO 90 DEGREE BENDS ALLOWED! It is a hollow tube, if it's piched/kinked you can throw it in the trash and buy yourself a new one. (It came packaged as a coil for a reason) As you uncoil it, go slow and easy.
Aug 22, 2007 | Lang Manufacturing EHS-APM Electric Oven
Zanussi ZBM799X Electric Single Oven Logo
53 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
