Question about Craig CR4100 Clock Radio
We have a Craig radio model CR4100U it powers up but no sound not even a hum . should we put it in the garbage or fix it we payed a hole $45.00 dollars for it at zellers last November .
Insinkerator model 55 hums
Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Mar 23, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Trailblazer buzzing coming through speakers
hi Scott, sounds like feedback try earthing your radio to the bodywork.
good luck Scott Craig
Aug 23, 2012 | Chevrolet TrailBlazer Cars & Trucks
Dishrag caught un disposal, pulled it out, blades turn, it just hums, it hums even when switch is turned on off!!
If cutter disk turns freely and motor hums, then motor winding has gone bad.
The humming sound means motor is overheating and will stop humming.
I wrote ez garbage disposal replacement steps from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming noise when turn on insinkerator badger 5XP, and it is not disposing food. After it is on for a while the reset trips
Your disposal is stuck. Sounds like something either fell in it, or perhaps a bone got inadvertantly tossed in. Do you own an allen wrench set? The garbage disposal did originally come with one, but it usually gets lost. The one that came with it will look like two hockey stick stuck together. In any event, you need one for the fix. There is a hole on the bottom of the disposal, directly in the center. Find the correct size allen wrench and place in this hole. Twist clockwise and counter clockwise until it is free. Once this is done, you most likely will need to hit the reset button on the bottom. Good luck!
Jan 18, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Insinkerator has power but does not grind garbage. have hit reset button and turned allen screw at bottom. now i dont get a hum from the motor.
Is it hardwired or does it plug into an outlet? If it plugs in, check the outlet for power. Is a circuit breaker tripped? How do you know it has power if it doesn't even hum?
Oct 14, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
1985 corvette bose radio
I had my delco rebuilt twice ,its in thier noiw not working.Call steve at c&s corvettes in Sarasota,fl tell him craig the wheel polisher,told you to call ,he sells rebuilt ones.If you want to keep it stock ,you have to pay the price.
Nov 23, 2008 | 1985 Chevrolet Corvette
Humming and static and not working
Angela You need to keep the system rewiried or at least checked out by a professional. It sound to me like the amplifier in the back of the car is staying on this would explain the battery problems and the hum. Sometimes when wiring in systems the amplifier will use the factory speakers in the car and will amplify the sound and you create a feedback loop. ( like putting a microphone in front of a speaker) If the amplifier is not on and the power cables are unhooked and you are getting this hum through just the radio. I would suspect a faulty radio. But I am guessing from what you described you have a miss wired stereo system.
Sep 09, 2006 | Sony CDX-F7005X CD Player
Craig CR4100 Clock Radio Logo
48 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
