Question about Sharp LC-19SB25U 19 in. LCD HDTV
I have two remotes. One to turn on the cable box and one to control the TV on/off and volume. When I was watching TV I hit the wrong bottom for the volume and now my TV is just noise and so picture. Can you tell me how to reset it? Thanks.
    Problem Solver:
  • 12 Answers
Program ur cable remote for ur tv and you will not experience this problem again. or alternatively call and complain to ur cable company that the installer never programmed ur remote and usually they will send someone to do it if you are incapable of doing so.
Posted on Mar 16, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
It sounds like you switched you TV to the internal tuner (if you had cable directly into the TV without a cable box)(TV Input)
You will need to set your TV to the correct AV input by pressing the INPUT button on your remote untill the cable box comes back.
The full PDF manual can be located here:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC19SB15U_LC19SB25U.pdf
I hope this helps,
Magoo
Posted on Mar 11, 2011
  • 11,361 Answers
If the cable from the cable box is attached to the TV via a coax cable, then all you need to change the TV channel to either Channel 3 or Channel 4. You may have accidentally push the CH button on the TV remote. Please post back what you find.
Turn up volume on panasonic tv
Hit volume on the remote or on the TV---if using a cable box make sure volume is up full from the,box
Mar 03, 2015 | Panasonic TH-42PZ77U TV
Sony RM-Y186 remote will not work what is wrong with it?
Hi!
1. don't press the buttons like a hardcore boxer :)
2. disassemble the remote control. No big deal. It has a plastic housing the buttons are on a plastic/rubber sheet. (remove batteries first)
3. clean the plastic/rubber sheet where the buttons are both on top and rear side. Take some clean petrol from the groceries next corner, and clean the black pads on the bottom of the buttons + also on the circuit sheet you'll find inside the remote control.
4. Put everything together and...
... TADAAA! It works again. :-)
Jul 20, 2014 | Sony Wega Tv Remote Control Rm-y180 4...
The volume on the tv at 100% is not loud, and I am not sure if there is a way to turn up the volume on the tv or through the HDTV cable box
There is something wrong with your cable box. Call the cable provider and they will walk you through setting it or do it remotely. They will not charge you for this.
Mar 30, 2014 | Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
Volume control does not work using the TV's remote, the cable remote or the actual volume control button on the front of the set - the volume that comes out of the TV's speakers is constant - about 33% of...
SO YOU JUST GOT A NEW TV ...BUT...THE VOLUME CONTROL IS NOT WORKING FROM YOUR CABLE BOX.
EASY! BRING UP THE IMAGE OF YOUR REMOTE FOR
YOUR CABLE (MORE THAN LIKELY, IT'S A UNIVERSAL).
CLICK ON THE REMOTE FOR INSTRUCTIONS FOR VOLUME LOCK.
IF IT'S A UNIVERSAL REMOTE, CLICK SETUP (TWO BLINKING LIGHTS) TYPE 993, AND HIT CABLE BUTTON.
VOILA! YOU CAN NOW CONTROL VOLUME FROM YOUR CABLE REMOTE!
Jul 03, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have mediacom cable TV and they gave me a universal electronics Atlas OCAP 5-Device Remote Control It is preprogrammed for my set- top box. I can not turn my TV off and on or turn my volum up and down,...
Not all remote control devices use the same signalling method for Infrared communication. You may have to get a true universal remote like a Logitech Harmony which can not only output most signaling codes but can learn codes from your existing remotes. It also permits one to define tasks, such as "Watch DVD" using a relatively simple web interface. Once programmed, pressing Watch DVD will cause it to turn on the proper devices with the proper inputs selected.
Note that these programmable remotes can be expensive. I bought an older Harmony 550 for a lower price and it handles my satellite box, stereo system, TV, DVD and VCR with one-button selections.
Jan 02, 2010 | Insignia LCDTV26 26 in. Television
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Sharp LC-19SB25U 19 in. LCD HDTV Logo
169 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
