Question about Savin Office Equipment & Supplies
I have a Savin 9020. Just put a new toner cartridge in it. Get an error code E5. Is this a major problem?
  • 17,970 Answers
Remove the copy cartridgte and look on the right side of the machine. Clean all the contacts you see with a soft cloth, maybe lightly saturated with alcohol.
Then on the door where the copies exit, open that door, you will see a metal, sawtooth shaped piece of metal, just before the paper exits the machine on that door. Take a brusk and gently clean the black ink off that sawtooth. Normally what happens is that builds up with ink and starts to arch causing the E-5 code.
You may want to check the socket that is one the upper left portion of that door to inspect the contacts for damage. Keep us updated.
Posted on Mar 11, 2011
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
Trying to replace toner in a savin 9922dp. install the toner cartridge, copier runs like it is loading the toner but then the error message to replace toner appears again (over and over)
take the toner out - whilst the green handle is up (this will get your hands dirty) feel inside for a left over cap from a previous toner. remove it and put your new toner in. this should sort it
Oct 02, 2013 | Savin 9922DP Toner 6 Ctgs/Ctn 66000 Yield...
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Savin 2527 indicates toner empty
i would suggest make sure the toner is the correct type, make sure when you install the cartridge it is tilted a little so toner will be towards the cap.
change your photoconductor unit.
Jul 19, 2008 | Savin Office Equipment & Supplies
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
