Question about Canon DC210 DVD Camcorder
My camcorder will not give me an option in disc operations to finalise a disc which I recorded on (which I did initialise before starting- I have also tried it on another disc, initialise, record etc) I dont know what to do, I have the correct discs, and I did finalise discs for my masters thesis project. I really need the data to be viewable on a dvd also when I play the recording back on the camcorder the I cannot hear the sound...what's happened here.. Please someone help, really desperate Sunshine
    President:
  • 1,901 Answers
Are you using the AC adapter when trying to finalize? You cannot finalize using battery power only.
Link to your manual:
Canon DC210 Manual
(What format discs are you using?)
Instructions for finalizing begin on page 61.
Hope this helps.
Thanks for using Fixya.
Posted on Mar 11, 2011
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
Finalising discs with canon camcorder
I do know that to finalize discs, you need to have your camera plugged in to a wall outlet, according to the owner's manual.
Jun 07, 2009 | Canon DC210 DVD Camcorder
Disc wont finalise
I'm only able to get the manual in Spanish
Here is a copy of it and you will see
I can't read it. Learning Spanish is on the to do list.
Aug 16, 2008 | Sony DCR-DVD608E DVD Camcorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Canon DC210 Camera
The error message is because, either
1. the disc was initialised on another camcorder, or maybe a PC, or
2. The disc has a recording on it in a different TV system (PAL v SECAM).
From the above, it may be you're using the same disc in two camcorders. To be sure of seeing what's on your disc you need to keep it with the same camcorder from 'initialise' to 'finalise' .
To be able to see the disc on a PC you need to finalise it on the camcorder. There's no other way to get to see your work on a PC.
Unfortunately I think you've lost your recordings this time.
Feb 08, 2008 | Canon DC210 DVD Camcorder
How to view DVD rewritables
Petra
Had the same problem, You have to press the mode button down which changes it to play and brings up the frames in the viewer. Then select Func, it will then give you a menu screen that shows finalise. What the manual does not say is press down the mode button to get the camera in play mode, when you do the gree light for play comes on.
Hope this helps
Feb 04, 2008 | Canon DC220 DVD Camcorder
Sony Handycam DCR-DVD 202E
i am getting a disk access error in sony camcorder..Not able to record any further..pl. help
Jan 12, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Mini dvd playback
Two problems here.
To JOA629 - You may possibly have initialised the disc in VR mode by mistake. VR mode discs will not play on a PC. Are you re-initialising the disc between when it works and when it doesn't ? If you're using VIDEO mode, are you finalising the disc on the camcorder before using it on the PC ?
To dewynn729 - you have intialised the disc in VR mode, which is a newer format than VIDEO mode. VR mode discs will produce .VRO file extension. Record your video on a disc initialised in VIDEO mode, finalise the disc on the camcorder (don't forget to plug the camcorder into the power adapter, and switch both on), then read the disc on a PC.
Dec 28, 2007 | Canon DC210 DVD Camcorder
Finalising
i bought a camcorder from currys model vp dc 172w back in october. i took it to las vegas to record my wedding. its recording fine but i cant finalize the disks. iam folowing the instructions from the book. on 1 disk its trying for about 30 seconds then is saying disk error. the other disks i cant even get them to start running. can you help me please.
Oct 30, 2007 | Samsung VP-DC161 DVD Camcorder
Unable to finalise
For some reason one of the discs that i have recorded on will not let me finalise. When i put the disc in it says recording disabled and then i go to the finalise menu and the finalise selection is unhighlighted. How can i fix this so i can finalise the disc and use it on my computer?
thanks
Oct 28, 2007 | Sony DCR-DVD602E DVD Camcorder
Canon DC210 DVD Camcorder Logo
133 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
