Question about Miele Red Star Bagged Canister Vacuum
Could I have a short in my cord? I can vacuum & then when I move the canister it shuts off, if I wiggle the cord it will turn back on. This last time, it just revs like a car trying to start & then does nothing. I live in a VERY remote area (80 miles from nearest Wal-Mart or McDonalds) so I know I will not be able to find someone to repair this for me. I have great doubt that I will be able to do it myself & my husband is an accountant so he is unavailable for another 6 weeks!!!!! Any suggestions?
    Sergeant:
  • 259 Answers
Whit the vacume plugged in and turned on start where the cord goes in to it and hold the cord whith each hand and bend it slightly. Move up the cord and do the same if there is a brake in the cord the machine will loose power until you bend the section back. When you find the bad spot in the cord unplug the machine and carefully cut the outer insulation away from the wires that are in the middle. Cut the bad section of the cord and resplice the cord wires by stripping off the insulation about an inch of each wire and twist them together and tape each wire with electrical tape so the bare wire is not exposed. Be sure when you splice the wires you do not mix the colors up. Then wrapp electrical tape around the section that you repaired.
Posted on Mar 11, 2011
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
Turns off and on
The on/off switch is defective and shorting out. Left alone, it could cause a fire, so replace the switch.
Apr 03, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
Why my vacuum cleaner intermittently starts and stips while cleaning The dirt bag is not full.
The most likely cause would be a short circuit in the cord. Let the machine sit running in one place without moving it, and wiggle the cord to see if this is the problem. If it is, the cord will need replacement.
Mar 04, 2011 | Hoover Vacuums
I have a Dirt Devil M130000 I Dual, which just shut off.
yOU MIGHT TRY LOOKING DEEP INTO THE DEVIL PAST THE CANISTER INTAKE AS THIS IS WHERE THEY CAN GET A HUGE CLOG THAT YOU CAN'T SE UNLESS YOU STICK YOUR HAND WAY IN THE UBE. DO THID WITH THE DEVIL TURNED OFF. CHECK FOR A SHORT IN THE CORD AS WELL BE SAFE FIRST.
Jul 23, 2010 | Dirt Devil M130000 ''i'' Dual Cyclonic...
The electric motor in the Power Nozzle does not work when the turned on.
There could be several issues with this. First determine if the problem is in the nozzle, hose or wand. This can be done by turning the unit on and wiggling the connections. One known issue with canisters is the cord that sticks out the back of the power nozzle goes bad, due to movement and normal use. There are also 2 electronic control boards inside the canister that give some problems. If you are unsure about looking at it, take it to a qualified repair shop.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 13, 2010 | Hoover S3765-040 WindTunnel Bagless...
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Sweeper stops running, when I jiggle the electric cord
The wiggle test is very popular and widely used. If you can gently wiggle the area that is in question and it can cause a change. Then yes, it is an electrical issue (loose wire or connection) but if not, and you have to be aggressive with the unit to get a change. Then it could be a bad motor.
Jun 11, 2009 | Filter Queen Majestic Canister Vacuum
No power to vacuum
try using a couple of different outlets .move the cord around at both ends you might have a bad cord
Apr 29, 2009 | Vacuums
Canister works, vacuum doesnt
There could be a break in the electric from the machine to the hose - or from the hose to the wand - or from the wand to the Power Nozzle - or it could be the motor is bad.
Wiggle the cord at the Hose with it running- then go to the Wand - then to the Power Nozzle. You may find a break in the wires anywhere along the line.
unplug the Vacuum:
If you have a meter check to see if the reset is working - and last check to see if the motor will work removed from the Nozzle.
Ralph
ifix@shentel.net
Oct 17, 2007 | Filter Queen Majestic Canister Vacuum
Miele Red Star Bagged Canister Vacuum Logo
109 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
