Question about Electrolux Microwave Ovens
I have an Electrolux over-the-stove oven Model #EI30MH55GSB. This microwave vents out the top and is causing condensation to build on our custom cabinets - which in turn is ruing the cabinet door. Any solution for this apparent design flaw?
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile JE1590--light bulb
You can download the installation guide here: http://www.geappliances.com/service_and_support/literature/
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
I would replace all the bulbs while you have it out so you can start fresh, so to speak.
Posted on Nov 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Posted on Nov 25, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: over the stove microwave install space
I would call Sharp at 1-800-SE-SHARP.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
rickzilla
  • 706 Answers
SOURCE: Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Posted on Aug 18, 2008
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
Electrolux otr microwave drawing air fromtop of microwave
I would direct you to first refer to your installation instructions to be sure everything is installed correctly.
Then I would refer you to the owner's manual for information on checking and cleaning / changing the grease filter or charcoal filter.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you need further help, you can contact Electrolux at 800-944-9044.
Sep 05, 2012 | Tappan TMT104E1 Microwave Oven
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
The LCD display is not showing the numbers correctly. It looks like the numbers are missing "lines", like an 8 can look like a 3, the 8 can look like a 0, etc. Any ideas?
It is the control board that needs to be replaced. The LCD display is connected to the board. If this is an above the stove microwave the problem was caused by the steam from boiling water on the stove top. you can prevent it from happening again by using the vent fan consistantly.
Dec 01, 2010 | Sharp R-1511 Microwave Oven
The exhaust system never has worked. Will not pull any air from the cooking stove under micro as it was supposed to.
Check the cabinet over the top of the microwave, the unit should be vented to the outside of your home, if not it was a venting model and just never connected to the vents.
Jun 14, 2010 | Maytag MMV4205 Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
Microwave Ovens Logo
116 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
