Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
I have two hand tools Black&decker drills / screwdrivers > KC 9018 and KC...
(More)
I have two hand tools Black&decker drills / screwdrivers > KC 9018 and KC 9019. both cannot be loaded anymore and are still in very good conditions.
Where can i get them repared !
I have had two cordless drill variable speed triggers burn up and render the tool useless (original...
(More)
I have had two cordless drill variable speed triggers burn up and render the tool useless (original and replacement unit).
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... ...
(More)
screwed 75 2 1/2 inch deck screws worked great, came back the next morning and zip doesn't work.... called the service number he said I over worked the drill and burnt the trigger up. sounds like bs to me but he said they would send a new trigger out for $15.00. does it pay to fix a problem of theirs????
