Question about Philips 55PL9223 55" Rear Projection HDTV-Ready Television
I have the Philips 55PL9223 Projection TV. The TV is turning itself off intermittently. Checked airflow filters and dusted internal components. Red light comes on after a few minutes of play and TV then simply powers off. There are no blinking indicators during power off. Can restart TV, but will power off again after a few minutes.......Please help!!!!
    President:
  • 1,623 Answers
Deffo sounds like its overheating, check the power supply capacitors for bulging etc
Posted on Mar 11, 2011
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Jan 06, 2016 | Philips Televison & Video
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Projection T.V.
It is called Ethylene Glycol (PTV Coolant is what you ask for) . I don't believe radio shack has it, you can try, however, all Electronics Parts Suppliers will have it. If your going to do all three tubes then get 3 - 16oz bottles.
May 18, 2009 | Philips 55PL9223 55" Rear Projection...
MY TV POWERS IT SELF OFF AND ON
Seems to be a possible heat problem, are all fans working and clean, is the tv surrounded by objects that could be blocking airflow or excessive dust, or smoke can damage alot of internal componants. Check all inlets and turn volume down to hear if fans are operating. May be something besides, but I would check the heat issue first.
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Panasonic pt 50dl45 shuts off buy itself
You probably have a lot of dust inside.
Open the back panel and vacuum.
Also use compressed air to blow into the components. Do not blow into the fan on the right as it will get the dust inside the lamp housing.
Oct 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
May 30, 2008 | Philips 55P8341 55" Rear Projection...
55PL9223 Questions about Lamp
lamp could run 200-325 would be my guess. check out ebay for one and get an extra if its a good price. lamps are common for going out.
Oct 31, 2007 | Philips 55PL9223 55" Rear Projection...
Flashing red light and shutting itself off
try to elevate the projection tv about an inch...
it well most likely work...
it's a ventilation problem.
Feb 09, 2007 | Philips 55PL9223 55" Rear Projection...
Philips 55PL9223 55" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
