HOW DO I HOOK UP THE TASCAM 900CD RECORDER TO A AUDIO DEVICE TO RECORD CHURCH SERVICES. I HAVE MASTERED THE IPOD AND KEY BOARD HOOK UP , BUT CANNOT FIGURE OUT HOW OR WHAT TO HOOK UP TO GET THE PREACHING SERVICE. THIS IS FOR A SMALL CHURCH AND I HAVE HOOKED IT UP WITH A FENDER PASSPORT 150. a diagram would help.
    Brigadier General:
  • 8,546 Answers
Something with a microphone, hmm?
Posted on Mar 12, 2011
We can't get the volume loud enough to hear when we record to a CD
This unit is a pro unit that makes use of XLR type inputs. These are typically at +4 dBm signal level not that of the -10 from RCA type mixing boards. So what you need to do is take the RCA outputs from your source and hook them to a IHF or unbalanced to Balanced converter and they are available from MCM Electronics. This device here should take care of the problem.
http://www.mcmelectronics.com/product/555-8485
Oct 06, 2012 | Tascam Cd-rw900sl Cd Recorder/player
Tas cd-rw 900 when recording in church services, it skips tracks. sometimes it only records for a few seconds and starts over.
If A.Track is on it will interpret silence (or near silence that meets user thresholds) as a new track. Disable A.Track with the Jog Dial when setting up to record.
http://audio.manualsonline.com/manuals/mfg/tascam/cdrw900sl.html
Page 26 under Automatic Track Division...
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/55030670_PM_EN.pdf
Jan 28, 2011 | Tascam Cd-rw900sl Cd Recorder/player
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Hi. I am using the Tascam 2488Mkii in a very simple set up. I love the sound of the single effect reverb. I just want to record my vocal and accoustic with that effect (recording via microphone)....
If you own a small practice guitar amplifier with reverb, mic the amplifier and hook your guitar and microphone into it and run it into the board. You will get a better sound
Nov 28, 2010 | Tascam 2488 Portastudio Multitrack...
Tascam CC-222 not producing quality CD's Help
You need to verify that the signal going IN to the recorder is ok. There are a number of ways you can do this, the simplest and cheapest is to get another recording device you know works, that takes the same connectors, and test using that. Something like a cassette deck, or whatever a church member may have at home. If that works, you've determined that its the Tascam, if not, then you need to trace back to see where the signal failure is occurring.
Jun 18, 2009 | Tascam CC-222mkIII CD Player / Recorder
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
Jun 11, 2009 | Tascam Music
Timing of Mastering and burning final copy to CD
I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
Hope this helps.
bd.
Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
I record using a pre recorded sound track, no problem there, then I recorded the voice.. Now how do I get to master this. IT tells me the track is too short and won't let me go into the Master mode. And...
how long is the track you are trying to master i believe it has to be over 30 seconds if your just sampling 8 or so seconds it wont work i know on some models its over a minute to be able to master mix a track.
thanks,
Nate
Aug 22, 2008 | Tascam DP01 All-In-One Recording Package...
Rcd-w500c recorder
if you still have this problem let me know. I hooked this unit up to our sound board and it is working. so let me know and I will provide details on how ours is hooked up.
Gary, 1007gary@gmail.com
May 02, 2008 | Sony RCD-W500C 5-Disc CD Recorder
131 people viewed this question
 Grubhead
Grubhead
