Question about Nikon S8100 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Posted on Jun 24, 2011
    Novelist:
  • 147 Answers
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Posted on Mar 12, 2011
On my Nikon Coolpix S4000, when power is turned on, the lens extends fully, opens, retracts fully, and then closes automatically. Lens Error then appears. It does not make noises and has not been used...
I had the same problem with a similar Coolpix model. It's an error on the lens mechanism. Maybe you pressed the lens by accident while they were retracting, or something like that... It's really a delicate mechanism. I think you have to send it for a service... Sorry!
Mar 15, 2014 | Nikon Coolpix S4000 Digital Camera
Nikon s8100 focuses only in center and rest has a
You need to replace the lens assembly. Aspherical lens needs precise placement of all elements.
Feb 15, 2012 | Nikon S8100 Digital Camera
Lens Error - Camera wont turn on or take photos as the lens wont open. The camera is only 3 weeks old and has taken 300 pics (S8100)
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Now as the camera is only three weeks old, you need to take it back to the store where you purchased it for exchange or refund. Do not attempt to repair it yourself at this point as it will void your warranty. Which brings up the next step, if the store refuses to help you, contact Nikon for warranty repair.
For others experiencing this problem, who do not have the luxury of warranty options, Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 19, 2011 | Nikon S8100 Digital Camera
Nikon coolpix s8100 lens error lens won't retract
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
Does the Nikon S8100 seem to have more lens error problems than other cameras?
Not really. It's extremely common on all similar designs from all manufacturers which have retracting/zooming lenses. The trick is to try and prevent the lens from ever being obstructed and to keep the camera in a camera case whenever it's not in use. Also avoid sand/beaches or similar areas as the camera isn't designed to cope with dirt which can get inside due to wind or being dropped.
None are robust, if they fail under warranty they get fixed or replaced. Outside of that you either fix it yourself or bin it and buy another as professional repairs usually cost more than buying another model.
Jun 20, 2011 | Nikon S8100 Digital Camera
Which brand of digital camera has the least problems with lens error? I'm looking at the Nikon S8100 and it sure seems like a lot of people are having this problem.
Hi, Overall I'd say Canon has the least number of lens errors I've seen followed by Panasonic then Olympus then Fuji then Nikon and in last place Sony.
Jun 20, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Nikon s8100 lens error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 09, 2011 | Nikon S8100 Digital Camera
Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
May 29, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens Error on NIkon CoolPix L2
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 31, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon S8100 Digital Camera Logo
1,782 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
