Question about Hoover Vacuums
Looking for a user manual for a Hoover shampoo polisher model 5464
2 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: I am looking for a
Generic problem for all Vacuums
I am looking for a
posted by csoper on Apr 18, 2008
Report abuse
I am looking for a switch for a Hoover floor polisher model 0211. This model is about 50 years old.
Hoover Floor Polisher #0211
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try your local vacuum dealer in your area in the yellow pages or you can try the Hoover fact serv but there is one other place the has been open since 1949 that may have the switch for you, either new or used. The companies and factory listings are listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 this is the company that has been in business since 1949.
Posted on Apr 18, 2008
Where can i get the shampoo? Can i find the owners manual online?
you should be able to get the shampoo at wal-mart and any place else they sell the steam cleaners. You do not have to use the eureka shampoo for this unit, however, it is more recommended.
I mean you can use the hoover, and dirt devil shampoo if you can find that, or something generic. Because the machine is mixing the soap for you with the water, anything will work.
As for the owners manual, you can get it here.
Nov 19, 2010 | Eureka Atlantis 2595A Upright Wet/Dry...
Need instructions for filling the Hoover Steam Vac Spot with cleaning solutions
Hi There,
Here's a link to the owners manual for your Hoover F5505 Steam Cleaner that will explain step by step how you can add water & cleaning solutions and carpet shampoo. I hope that this was helpful to you. If it did help you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair.
Hoover F5505 SteamVac Spot Vacuum Product Manual:
http://www.hoover.com/pdfs/manuals/F5505.pdf
Thank you, this is really appreciated.
Chris J.
GoVacuum.com
Apr 06, 2010 | Hoover F5505 SteamVac Spot Vacuum
Attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Oct 30, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Looking for instruction manual for Bissell Pro 2 carpet shampoo machine
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need a booklet for my Steamvac-Dual V Widepath with auto rinse shampoo machine. The Model # is F7425-900 SeriesAA 12.0. Please send me one.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=736301
Posted by wolners2 on Jul 03, 2008
I need a booklet for my SteamVac-Dual V Wide path with auto
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F7425-900 Series AA 12.0 Amp. In order to get the owner’s manual for the Hoover SteamVac-Dual V Wide Model # is F7425-900 SeriesAA
12.0. you will need to contact the Hoover factory cust serv and request the owner’s manual from the Hoover website or the Hoover cust serv. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 03, 2008 | Vacuums
Need manual
To all the users looking for this manual.
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Regards.
Jun 29, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
I am looking for a switch for a Hoover floor polisher model 0211. Thsi model is about 50 years old.
I am looking for a
Report abuse
8 a.m. - 7 p.m. EST
Apr 18, 2008 | Vacuums
Hoover aquajet
May have a bad pump, but need model number to be able to look it up.
Jan 03, 2008 | Vacuums
Vacuums Logo
208 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
