Question about Sanyo DP26648 LCD TV
How do you clean the screen on a Sanyo DP 42849 LCD T.V.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
  • Turn off the TV
  • Apply gently pressure and use a soft lint free cloth to remove smudges and fingerprint. (avoid paper towels/toilet paper/tissues) as they can end up scratching the screen
  • You can use small amounts of distilled water or non-ammonia based cleaning products, do NOTspray directly onto screen instead lightly moisten the cloth and follow up with a dry cloth * ammonia and alcohol based products can often haze the screen often dimming the display
  • There are special products you can purchase that provide anti-static properties to help prevent the dust from accumulating. Check you local electronics outlet if your interested or go to the link below from amazon.
http://www.amazon.com/Philips-SVC2548G-27-Cleaner-Computer/dp/B003DNS89G/ref=pd_cp_e_2
I hope this helps,
Magoo
Posted on Mar 11, 2011
What might cause the screen on my sanyo DP 42841 to turn green and stay green? Everything else works fine.
It is a bad symptom. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 21, 2016 | Sanyo Televison & Video
Can i use a digital converter on my Sanyo DP 42849
Sounds like you need a stronger antenna or to adjust your antenna. It's pointless to put a digital converter box on your tv as it already has the capabilities of reading digits signals built in.
Jul 25, 2016 | Sanyo DP42849 42 in. HDTV
What is price for screen for sanyo dp 42849
Here this should help.
www.coppelltvrepair.com/p/429/sanyo-dp42849-p42849-01-backlight-inverters-replacement-for-dark-screen-no-image-problem
Nov 24, 2015 | Sanyo Televison & Video
How do i fix a tv sanyo DP 42849 IS NOT TURNING ON
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Electro help
Nov 13, 2014 | Sanyo Televison & Video
HOW I CAN TURN ON MY SANYO DP42849. THE SCREEN IS OFF
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Where can i find a flat screen tv .replacement screen for a sanyo 42" model 42849-05 new or used.
This is a mistake more than you realize. Screen versions and models are different and quality varies. The QC can be different as well depending on the production lot. You may replace the unit but have an immediate failure or bad quality.
Jul 11, 2014 | Sanyo DP42849 42 in. HDTV
Sanyo DP 42849 42'' lcd tv no audio no video
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 03, 2017 | Sanyo DP42849 42 in. HDTV
MY 32" SANYO SCREEN BROKE, MODEL # dp 32647.
you got the new screen in the compuny there you live
Feb 08, 2009 | Sanyo DP32647 32 in. LCD TV
Sanyo DP26648 LCD TV Logo
240 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
