I used the self clean feature on mine and found that it got so hot that it burned out the sensor and ended up with the same symptoms you are describing. Had to have the sensor replaced. DO NOT USE THE SELF CLEAN
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
