Question about Health & Beauty
My go go elite travler doesn't seem to be as fast as it used to be and the scooter doesn't seem to be able to run as long as it used to.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Please visit:alldatasheet.com
Posted on Mar 12, 2011
Tazora elite. Has locked up on me two times now. Almost throws me off scooter. Battery just charged. H ow do I tell if it's a battery problem or a motor problem?
Some scooters are fitted with an electric safety brake which engages when the power is off.
While there could be a mechanical fault with the transmission or motor this would seem unlikely as when the fault is absent the scooter presumably runs ok.
It would seem the electric brake is engaging either due to a fault in the brake or because of an interruption in the power supply to it. That might mean the battery but unlikely. That would be fairly obvious as the complete machine would die at the same time it stopped and you made no mention of that.
Sep 04, 2016 | Tzora ELITE Elite Easy Travel Scooter
When push I push to go forward its real slow and backward runs fast
strange if no one has played with it it could b youre little control box..........cheers.
Aug 06, 2015 | Elite Pride Go Go Traveller 3 Wheel
How do i remove the battery from my go go elite scooter..?
If it is like my Pride Go Go Traveler Elite scooter, what they don\'t tell you is that you need to give the battery a sharp jerk to make it release and come off the scooter. You can\'t just pull it strong and steady.
Apr 26, 2014 | Pride Mobility Products Go-Go Elite...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
Benelli pepe engine doesn't switch off
Hi Perth1000, you may need a new ignition switch and I am sorry you can't find the first and best tool you ever bought for your Benelli but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
honda scooter elite 110 ignition replacement
Ignition Switch Wires HELP Honda Elite 250
Replacing ignition switch BMW motorcycle
Benelli Pepe 50 2008 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.benelli-scooters.de/pdf/BA_Benelli_Pepe_lx.pdf
Mar 16, 2013 | 2008 Benelli Pepe 50
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
My pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
Apr 17, 2009 | Elite Pride Go Go Traveller 3 Wheel
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
