Need cable from outlet to printer - Office Equipment & Supplies
  • 374 Answers
If "outlet" means 120 Volt AC Power Outlet, then you need a standard 3 wire PC power cable.
If "outlet" means the UBS port on your computer, then you need a USB A to B cable.
If "outlet" means the parallel port on your computer, then you need a computer parallel port printer cable
All of the above are available at computers stores, Stapes, Office Max etc.
Regards,
Yavacotech
Posted on Mar 11, 2011
Error E0 on laserjet m1132 mfp how to clear it
Hi, the error E0 is for a paper jam, please make sure your laserjet M1132 paper tray is not to full. You can also do a power reset by..... 1) disconnecting the power cable from the back of the printer........ 2) disconnect the power cable from the wall outlet. 3) Wait up to 10 seconds and reconnect the power cable back to the wall outlet first, followed by the back of the printer. 4) Turn On the printer again.
Connect your printer directly to a wall outlet. (don't use a power hub or a surge protector)
??Here is a screen grab from the manual. If you need the who manual as PDF replay. Or if you have it, please read pages 189-210+.
Nov 22, 2016 | HP LASERJET PRO M1132 MFP
I need to know where to plug power cable and what type power cable i need
When you buy a printer power cable tell to the salesman/saleslady about the model of the printer for them to match your printer...
You can locate the input power chord into back or side of the printer...then plug that power cable into outlet to power on the printer
Note: Do not power on the printer until your pc configure it
Sep 20, 2011 | HP PSC 2210 All-In-One InkJet Printer
Printer will not turn on ,power button just blinks when you press it down.
Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable into the electrical outlet, and turn on the printer.
If it does not work, contact Dell support. You probably have a faulty power source.
Mar 10, 2011 | Dell 966 All-In-One InkJet Printer
I dont have installation to instALL MY f4280 DESKJET ALL IN ONE PRINTER, I NEED TO INSTALL IT ON MY COMPUTER, WHAT DO I DO?
  • Lets’, see if this fix it.” Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug-in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. “I hope this, Fix it.”
Feb 20, 2010 | HP DeskJet F4280 All In One Printer InkJet
Won't print
The printer needs to be connected to the wall outlet, and to the computer. That means you need two cords: a power adapter (to wall outlet), and a USB cable (to computer). You also need printer drivers installed. Those come with the printer, on a CD. The printer generally needs to be powered ON for the computer to recognize it.
Feb 02, 2009 | HP Officejet 5610 All-In-One InkJet...
I can NOT setup the printer on an ethernet network at home
You can get an Ethernet adapter for HP printers that plugs the USB in one slot and then an RJ45 cable from the other to the network. Good luck.
Jan 15, 2009 | HP PSC 2410 All-In-One InkJet Printer
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Printer won't communicate
Verify your printer is compatible with your computer.
The printer supports Windows XP, Windows XP Professional x64 Edition, and Windows 2000
Correct communication problems between the printer and the computer.
  • Remove the USB cable from your printer and your computer. Reconnect the USB cable to your printer and your computer.
  • Turn off the printer. Unplug the printer power cable from the electrical outlet. Reconnect the printer power cable to the electrical outlet, and turn on the printer.
  • Restart your computer.
Aug 19, 2008 | Dell 946 All-In-One InkJet Printer
Printer won't print says USB is not hooked up
Alignment failed
Just try to reset the Printer.the pro L series printer can be reseted as follows.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
FULL NVM RESET:-Turn the printer OFF, Disconnect the power cable from printer and from the wall outlet.Wait for 1 minute.Connect one end of the power cable to wall outlet.Press and hold # and 9 button and connect the Power cord while holding.After connecting , release the button.Then Turn ON the Printer.
(Notes - resets will take a while)
Feb 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
k24674
jasbo
jasbo
