Question about HP DeskJet 6988 Printer
Just bought a NetGear WNDR 3400 router and used the set-up wizard. Set-up was successful and two my two laptops are commiunicating with the router and I am able to get on the internet. I can't get an HP 6988 Wireless Printer to print. It wouldn't set-up using the Easy Set-up method. I tried setting it up using the Wireless Set-up Wizard in the Control Panel using a flash drive and it said it was successful. The signal light and network light are on and not blinking but it still won't print. Any suggestions?
    New Friend:
  • 11 Answers
Is the printer software installed on the laptops? Are you trying to print from the laptop itself, or a phone or tablet?
Sounds like from what you said the devices are on the network, but they still need the correct software to communicate with each other.
Try to use a smartphone and install the HP mobile printing app, if that app is able to find your printer, it is indeed on the network correctly.
If you can print from the phone/tablet, but not the laptops, you need to install the software drivers for your printer to your laptop(s) you wish to print from.
Here is a link to the Windows Drivers
HP Software drivers - HP Deskjet 6988 Printer Software and Drivers
Posted on May 16, 2017
  • 234 Answers
SOURCE: wireless connection issues
First open services goto start Run type services.msc and see for the entries (hp cue discovery , hpqcxs08 and hp network device) and make sure they are enabled.
Then Goto device manager (Right click on computer and then properties then device manager) Here click on View and show hiden devices and under network adaptors see if you have a red X on HP Printers then delete all he etries you have for HP here (If t prompters a restart restart later) after you have deleted all you may restart your computer.
Then start to install or add a device from the disk.
If it finds the printer do not click on next got to device manager then view and show hiden devices and see if you have the HP Printer with a Red X if yes right click on it and enable it (If it prompts a restart DO NOT RESTART) close this device manager window and in the instalation widow click on next and it should complete the installation.
Good Luck
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: HP Photosmart C7280 wireless connection
I discussed this with an HP tech & worked on the solution myself to verify his answer &, of course, he was right!
Your printer will only recognize one connection: either wireless or hardwired but NOT both. That is why it keeps switching back to hardwired mode.
Posted on Jan 09, 2009
  • 165 Answers
SOURCE: hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Posted on Feb 24, 2010
SOURCE: I have a HP Photosmart B110A. The printer worked
Think I have sorted this one out. Download FULL drivers package (I went through HP printer diagnostics to get to this). When main install screen appears select 'ADD Device' and follow it through - my B110a now works perfectly, and wirelessly for both printing and scanning. Hope this solves your problem.
Posted on Mar 18, 2011
Testimonial: "Many thanks for your help!"
  • 126 Answers
SOURCE: How to set it up
Hi, To set up wireless communication using the device control panel with wireless setup wizard, please follow this instruction:
The Wireless Setup Wizard provides an easy way to set up and manage a wireless connection to your device.
NOTE: To use this method, you must have a wireless network set up and running.
1. Set up the device hardware (see the getting started guide or the setup poster that came with your device). 2. On the device control panel, press the Setup button. 3. Press an arrow button to move to Network Settings, and then press OK. 4. Press an arrow button to move to Wireless Setup Wizard, and then press OK. 5. Follow the display instructions to complete the setup.
I hope this helps!
Posted on Sep 01, 2011
How to setup netgear wndr 3400 wireless router
The Netgear WNDR 3400 wireless router configuration process is quite easy. Before you start installing and setting up the router, you should first check the packaging contents. Also, try to become familiar with the router's front and back panels, the LEDs and the necessary details on the router label. If you still experience any problem during the setup process, you can contact the technicians. More information, visit -Netgear Customer Service Technical Support Number USA 2017
Apr 29, 2014 | NetGear WGR614 Wireless Router
Lost passkey to my Netgear N600 Double Band Router wndr 3400
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.or passphrase etc.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
Apr 04, 2012 | NetGear N600 Wireless Dual Band Router
I have a new Netgear WNDR 3400 router. PS3 and iPods connect to internet. Toshiba laptop receives the router signal, but wont connect to internet. help!
Most likely a DHCP or DNS problem on the laptop. To confirm this open a command prompt Windows Button > type "cmd" <enter>. Now at the command prompt type "ipconfig". Scroll up to the top of your output and you should have an "Ethernet Local Area Connection". Your IPv4 address should start 192.168.x.x. If yes you are getting a valid assigned IP via DHCP, if you get 169.x.x.x then you are not. To fix Click windows button > All Programs > Accessories > right click command prompt and click "Run as Administrator". Now type "ipconfig /release" followed by "ipconfig /renew". Give it a few moments and check to make sure you get a 192.168.x.x IP now and you should be good.
Nov 10, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
How to instal
You'll wanna check out:
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
My netgear wndr 3300 wont broadcast the n network and my laptop has a n network adapter
Check with the Settings on Router
Since u have a Dual band Router, Check which is Enabled
make Sure u have the N Network Enabled or Not......
Check and All the Best...........
Oct 05, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Where to get the smart wizard installation assistant disk for netgear n router wndr 3300. I have tried the manual but it is not working
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 07, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Ar5b93 wirless in acer 5740 laptop does not recognise 5GHz network from netgear WNDR 3300 router
5Ghz network is only for wireless G+ or wireless N compatable devices only.
Feb 14, 2010 | Acer Computers & Internet
I recently bought a Netgear WNDR 3300 and when I try to set it up, using their CD, it says it is not compatible with my Sony Vaio 64 bit laptop.
Do know if this will help but seems a common problem with this hardware, try this address;uo
Jul 12, 2009 | Computers & Internet
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes and Netgear
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HP DeskJet 6988 Printer Logo
159 people viewed this question
Ben Johnson
