Question about Philips Televison & Video
I have a Magnavox 20MF251W/37 that when I plug it in it turns on to the standby mode (red power light). When I power it on with remote or by pressing power button it does turn on (blue power light). Shortly thereafter, I do see an image (snow at this point since I don't have it plugged to any video source). However, that image stays on the screen for only 1 second then disappears. The unit is staying on and is NOT going back into standby mode (power lights stays blue). I have replaced main unit board with a working one - same result. I have replaced power supply board with a working one - same result. I've checked all wire connections don't seem to have any loose fits. Is it LIKELY this problem is associated with the backlight inverter board (I don't have one of these to test it with) or is it LIKELY some other problem I need to investigate?
  • Terrie Mar 14, 2011
    Thanks for your initial response jdvillanueva: Is it possible to determine the precise problem (e.g., leaky driver transitor or leaky/shorted coil) on the inverter board and repair it or does the entire inverter board have to be replaced? If the entire board has to be replaced do you have any other suggestions besides ebay and shopjimmy for purchasing such a board? If the board can be repaired - is the process similar to replacing a bad capacitor (as I've done this on other TVs) or should it be done by a repair shop. If the repair should be done my a repair shop can you recommend a service provider?
  • Philips Master
  • 2,098 Answers
Hi tempcheck,
Lot of brand have a common symptom when there's a malfunction in inverter board, it will automatically shuts down the unit. This is because there is a protection circuit designed connected from this board to the main board(other brand from the feedback of power supply) that undergo self test while the power supply initialize. I've suspected that you're inverter board gone to overload or produced over voltage due to either leaky driver transistor or leaky/shorted coil, changed of resistance value of some resistor. I've already checked ebay.com and shopjimmy.com but you're board is out of stock, try other sources for replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Posted on Mar 11, 2011
  • Jdvillanueva
    Jdvillanueva Mar 14, 2011
    There some shop that repair even the board only, this will be go to series of test on the parts like what I've mentioned. Defective transistor is easy to find out by an experienced technician same as the coil, capacitor and resistor. Also another option is to ask your local Magnavox service center for the availability of the board. I can't suggest you a local repair shop because I'm not familiar to your country.
Rca remote and magnavox lcd tv/dvd need code
This is the setup code for your Maganavox combo. 0456
Aug 25, 2012 | Magnavox Used Original 20MF251W Remote...
Magnavox 47MF437B/37 works fine until turned off. The red standby light comes on but the TV will not turn back on again. I have unpluggged the TV then plugged it back in again. Sometimes the the TV will...
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Jun 12, 2011 | Toymax Magnavox 47MF437B 47 in. LCD TV
Magnavox 51MP6200D/37, when watching, the picture faded to black and then the sound went within a minute. now the power light just blinks and to turn it off we have to unplug it.
maybe you set it in freeze mode or timer.... the blinking reason mostly is for freeze and standby mode.... try to rest your program in tv.
May 27, 2011 | Vizio L32 32 in. LCD HDTV
Power light is on (Red & Green) but no picture
this like your tv at stanby mode, turn on with remote control, if no effect this mean you must contact service center
Jan 18, 2011 | Philips Magnavox 26MD357B-37 26 in. LCD...
Powers on but no picture or sound
i need a screen off a 47inch magnavox if u coudent fix urs and ur interested in selling me ur screen let me know
(47mf437b/37) noe28cervantes@yahoo.com
Jan 04, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
Screen seems to stay on after powering off...
stand by should be when the power button turns red. There is also an off mode but it requires you to use the button on the front of the tv. Only problem with this is the remote doesn't work when the tv is in the off mode.
Jan 08, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox 20MF251W won't turn on at all
my tv is not rurnine on the standby light is on
Aug 27, 2007 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
Programming Problem
Try the Philips codes as well...
Jun 09, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
