Question about Nintendo Wii Console
My tv buzzes when I plug in my audio cables from my wii. I ordered a new cable and it is still doing the same thing. How can I fix this?
    Scholar:
  • 78 Answers
Most of the time this buzz isn't caused by the cable, but by the way the cable is resting in the output slot of the Wii. To fix this adjust the plug's position in the Wii (jiggle it around) until you find a position where the buzz stops. When you find it, try to tape the cord into that position. It's not pretty, but it works.
Also, it is technically possible the buzz is coming from where your cable enters the TV, though not likely. If the method I described above does not work, try it with your TV.
Posted on Mar 12, 2011
I HAVE A NEW 20" eMERSON TV. I JUST BOUGHT A wii SYSSTEM AND HAVE THE 3 COLOR CODED CABLES INSERTED. tHE CABLES ARE RED WHITE AND YELLOW, THE TV ONLY HAS RED WHITE AND ORANGE! I CANNOT FIND A CHANNEL...
You should order an hdmi cable for the WII so that it will connect. Right now you have audio (red and white) and video (yellow) the new television sets dont use that anymore.
Nov 18, 2013 | Emerson EWF2004 20" TV
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
I bought a new TV and hooked up the Wii like I normally would and when I turned it on and was looking at the selection screen, (game, netflix, other various things) I noticed that the Netflix icon was...
Hello.
Try inserting the RCA (yellow, red, white cable) into a different port. There are usually an RCA port at the back and at the side of TVs. You can also try interchanging the RED and WHITE cable and see if the problem will be transferred to the WHITE cable, then you will need to replace the cable.
Aug 06, 2011 | Video Game Consoles & Games
Just bought the RCA1023 and i have a buzzing sound trying to fix it i have it hooked to my tv through the HDMI cable i also have the audio cords (red and white) hooked up and i am still getting a very...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still does it with no cables or anything external attached it
Apr 01, 2011 | RCA Audio Players & Recorders
No sound on wii
Hello :
1: Make sure you have the volume on the TV turned up and the audio-video connections plugged into the same-colour plugs. Sound only kicks-in once you are at the Wii menu. If this doesn't work, continue to step 2.
2. Test the Wii with another TV. If you have sound there, then it is possible that the HDTV's sound inputs plugs are damaged. Send your HDTV off for repairs.
3. If the Wii does not work with the other TV, then it is likely that the audio cables are damaged. Order a replacement from Nintendo (instructions are in the Wii user's guide)
good luck .
rate please !
Mar 26, 2010 | Nintendo Wii Console
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
No Sound from TV when using Component Cables
what you do is plug in the HD cables as you previously stated and then place the red and white cords where you would normally put then like when you plug in a dvd player or the place you normally would plug in the red and white cables.
Apr 16, 2009 | Nintendo Wii Console
How to get wii game to work on tv i have a sylvania tv
The Wii console should have included a cable to plug into the AV Multi-out Connector. This cable has the plug for the Wii on one end, and three RCA plugs on the other. They are color-coded yellow for the video output, and red and white for right and left channel audio outputs. These plugs would go into the corresponding RCA input jacks on your TV (if it has them), and you would select that input using the TV remote or front panel buttons.
If your TV doesn't have A/V inputs, you need to get an RF converter. This device takes the A/V signals from the Wii and converts it to a signal on channel 3 or 4 so you can tune it in on your TV. These cost around $15 at Wal-Mart and other retailers.
If you have lost your Wii connecting cable or didn't get one, you can order replacements from online vendors.
Mar 28, 2009 | Sylvania 6427TE 27" TV
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
