Question about Epson LQ-2090 Matrix Printer
A medio imprimir con la impresora lq 2090 se pausa y emite pitidos como si se hhubiera colgado
4 Suggested Answers
alvinbga
  • 130 Answers
SOURCE: Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Posted on Jun 19, 2008
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
Joed911
  • 4338 Answers
SOURCE: HOLAS COMO NENCESITO EN DRIVER
Aqu? est?n a conductores para Epson LQ-2080. Por favor, seleccione a conductor para descargar. Adicionalmente, puede escoger Sistema operativo ver a los conductores que ser?n compatibles con su sistema operativo. Si usted no puede encontrar a un conductor para su sistema operativo, puede preguntar por los conductores para su sistema operativo en nuestro foro
http://driverscollection.com/?H=LQ-2080&By=Epson&dpage=2
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Posted on Nov 24, 2010
Como soluciono el error B200 de la canon MP250
De acuerdo a lo que lei en un foro esto se produce por recalentamiento del cabezal al imprimir con un cartucho sin abastecimiento de tinta, tienes que cambiarlo o prueba con desintalar la impresora del windows y lo reinstalas despues.
Aug 30, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Feb 25, 2011 | Kodak ESP 5 Printer
Como aser para recetar chip de la T430
1. entra el menu de CONFIG de la impresora. Para hacer esto:
1. enchufa de la impresora.
2. con la impresora enchufada lejos, aprieta y sujeta tanto el boton Selecto como el Regreso abotonan.
3. al mantener ambos estos botones presionaron, enchufan la impresora atras en.
4. cuando la pantalla de impresora dice que MENU de CONFIG o Principal Valor de Cnt, suelte los botones.
2. aprieta el bot?n de Menu de flecha hacia la derecha hasta que vea Repone Maint Cnt (o Repuso Maint a Conde) como una elecci?n.
3. aprieta el boton Selecto una vez. Debe ver Repone Maint Cnt en la l?nea primera y = Repuso en la segunda l?nea de la pantalla de impresora.
4. prensa Selecciona otra vez. Esto repondra al conde de mantenimiento para poner a cero.
5. salir el men? de CONFIG, aprieta el Regreso hasta que regrese en el principal menu.
6. aprieta la izquierda o boton de Menu de flecha de derecha hasta que vea la Salida Config Menu como una eleccion.
7. prensa Selecciona. Esto debe guardar que poniendo y vuelve la impresora al modo Listo. La NOTA: Si usted se pierde durante cualquiera de estos pasos, apriete el boton del Regreso para volver al principal menu. Hacer esto no cambiara ningun ajustes. Alternativamente, puede enchufar lejos la impresora por unos pocos segundos y comenzar otra vez.
Feb 18, 2011 | Lexmark T430 Laser Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ┬┐Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
Que controlador debo descargar, o que parametros debo modificar para que la Ricoh Oficio 3245c me respete los parámetros que por defecto establezca para impimir con un aplicativo en Foxpro 6.0 ?
El programa se adapta a la configuración de la impresora en cada momento. Si, por ejemplo, se diseñó un informe para formulario tamaño A4, al momento de imprimir se debe configurar la impresora para ese tamaño de papel. Esto se hace desde Panel de Control, Impresoras, y en la predeterminada se ingresa por propiedades. Se debe establecer el tamaño de papel en A4 si, por ejemplo, está establecido por defecto en tamaño Carta. Desde un programa VFP se puede utiizar un comando para que, antes de imprimir el informe, muestre las opciones de impresión a fin de que el usuario pueda modificar, por ejemplo, el tamaño del papel: REPORT FORM MiReporte TO PRINTER PROMPT
Saludos cordiales
Sep 24, 2010 | Manuel Esteban Je joue e Kraland
Hp 4215 all in one solo me da la opcion de fax
como puedo instalar mi impresora, ya que no cuento con el disco de instalacion.
Mar 17, 2009 | HP Officejet 4215 All-in-One Color Photo...
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Sep 10, 2008 | Office Equipment & Supplies
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
Red light flasing
si miras donde va el cartucho, ves un alambre (metal) al lado derecho? Ves que este alambre esta medio suelto? ves que este alambre a dañado el cable de atras? el que lleva las señales del cartucho la impresora?
bueno e pregunto todo esto porque me ha pasado a mi. Este metal se ha suelto en los dos (color y negro) y me ha dañado los dos cables de atras. ahora la impresora no ve si hay cartuchos o no.
puede que este sea tu problem.
Escribeme y me dejas saber si este es tu problema queria llamar a HP para decirles que tienen un producto con problemas y ver como resuelvo el remplazar la impresora
ngr7000@hotmail.com
Rafael
Jun 30, 2008 | HP DeskJet 9800 InkJet Printer
Epson LQ-2090 Matrix Printer Logo
206 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
