Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Icemaker has quit making ice. Does the water filter affect the flow of water, etc. to icemaker? Refridge is about 6 mths old
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
Master_Tech
  • 770 Answers
SOURCE: GE ice maker problems
to cycly that im you need to have the door switch closed as well have you held that while trying to cycle it?
Posted on Jun 09, 2008
SOURCE: water dispenser in fridge
Possible problems could a bad water valve (dual valve), bad micro switch which is activated by pressing the button for water to come out. On some models the bracket that holds the micro switch could be broken not allowing the button to activate.
Posted on Oct 05, 2007
the dr
  • 447 Answers
SOURCE: ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Posted on Nov 19, 2007
ghappliances
  • 126 Answers
SOURCE: Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
My ice machine no longer produces any ice cubes? the machine is about 3 years old. Got it from Home Depot. Is this under warrenty? who should I call for repair service or what can I do to determine a...
If the filter is really bad it won't make ice becuuse the water can't get to it. A way just to check to see if the icemaker is working is to pour a small cup of water into the icemaker and see if runs through the cycle a makes a batch of ice, try the cup of water before you call anyone. If it makes ice then either you need to change the filter(which you should do anyway) or you have a bad water valve. If it doesn't make a batch of ice then your icemaker is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by Side refrig. ice maker has water in tray but does not dispense ice.
Check to see if the coils under refridge are clean . If they are , replace the icemaker . An icemaker has to be 5 degrees to dump the cubes . Dirty coils can raise the temperature to 6 or even higher , therfore the icemaker will make ice , but not dump them .
Aug 26, 2009 | Whirlpool Refrigerators
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
No ice
IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No water comes out of ice and water dispenser. gsh25jsrfss refridge no water is flowing to icemaker or water dispenser.
Either the inlet filter is plugged, or the valve is not opening. You will have to trace the water line to access these.
Jul 06, 2009 | General Electric GSH25JSXSS Stainless...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
665 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
