I purchased two Wharfedale W70 speakers probably in the 1960s. One of the two connected to the same amplifier will no longer emit sound. I removed its back and all wires are soldered in place and all three cones are not damaged. Howerver, all three speaker cones, the tweeter, midrange, and woofer seem to have a problem with their coils. I live 30 miles west of St. Louis, MO and need to know where in the St. Louis area I can take it for repair.
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
  • 8 Answers
SOURCE: headphone jack point
dont mean to state the obvious but have you tried another set of earphones? ie.. maybe its a problem with the cable
Posted on Mar 01, 2008
  • 121 Answers
SOURCE: Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and If it is close to 4 ohms check the wiring and and at the speakers, most likly the receiver/amp is not blown.
Posted on Apr 20, 2008
  • 6 Answers
SOURCE: no sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Posted on Apr 28, 2009
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
How to connect a wharfedale mp2800 amp to a yamaha p7000s amp?
You may feed the signal from one source ,cd player,tv,etc.into both amplifiers separately;but you can not connect the amplifiers together.Let them each drive separate speakers.
Aug 16, 2014 | Audio Players & Recorders
I won't bore you with the long, tedious reasons for the question, but I need help in connecting the amplifier cables to my Wharfedale 8.3 speakers. There are 4 connection points on the speakers: two...
Leave them in, do some reading on Bi-Wiring (BUY Wiring), chuckle to yourself and enjoy the sound. Connect one positive to a positive and one negative to a negative. With the jumpers in place there is no electrical difference.
Jul 29, 2011 | Wharfedale Diamond 8.3 Main / Stereo...
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
Hello, I have a woofer from a set of diamond 8.3 Wharfedale speaker. The woofer sounds like the coild is rubbing and emits a scratching sound. Looking for possible repir solution and the model no. for the...
The voice coil of your speaker is scratching with its magenet body inside. It can't be repaired. Whatever we do will go in vein. there is no possibility other than replacing this speaker. Some people will recone it, but qulaity cannot be assured. it will sound; but with respect to the other speaker, it won't match. Coil position, resistance, number of turns per unit length ete are determining the magnetic strenth of the coil, and therby sound. Wharfedale eill have its secret, and they wont give it out, as they have gained it with tremndous reserch.
So in my opinion, it will be best for you to replace the damaged speaker with and other one of same type and number. All details will be printed on its body. Buy the original one. Do not compromise. Woofers are the heart of any sound system. Keep this in mind. OK.
Mar 31, 2011 | Wharfedale Diamond 8 Cinema System
My WHARFEDALE DIAMOND SW150 SUBWOOFER does not work. the light (red) comes on when connected. but no sound. I've tried direct from speaker and from receiver connection. doesn't work. Any advice
After finally finding the circuit diagram for the Wharfedale SW-150 sub woofer, I've managed to identify and fix a fault which has the same symptoms as yours.
The problem was with the largest of the two relays (Relay 1 in the attached photo).
The circuit has two power rectifiers, the first rectifier provides the small current for the system to operate in standby. Relay 1 is normally closed and this turns on the secondary power rectifier that powers the amplification circuit.
Relay 2 (smaller and black) is used to prevent the speaker from popping every time the auto-power switches on/off, it uses a delay to allow the amplifier to stabilize before activating the relay which connects the amplifier to the speaker.
On my system the power LED was lit, but the little click that happened about 2 seconds after power-on, was no longer heard. The little click that was missing is the sound of the smaller relay connecting the speaker. This relay was not activating because the amplification circuit had not been powered.
The larger relay does not need to activate to turn on the amplifier, as it is normally closed, meaning the the default connection state is to provide power to the amplifier. The relay is only used to disconnect the amplifier when the auto-off feature kicks in (or the system over heats). I could test this relay was clicking by connecting pins 1 and 3 on the temperature switch connector.
So the relay was not connecting properly in the closed state. This is what the relay looked like on the inside.
Mar 16, 2011 | Wharfedale SW150 Subwoofer
Can I connect my floorstanders to wharfedale sw150 without any external amplifier, If so, how ?
What 'floorstanders'?
Its internal amp is for its own subwoofer ONLY, but if you use your own amp's full-range speaker-level outputs to feed two chanels entering the sub you can tag the 'floorstanders' onto the sub's speaker terminals as speaker wire extenders. Your amp will be powering the floor units.
I'd keep the sub separate and feed it LFE only if it was mine.
Feb 02, 2011 | Wharfedale SW150 Subwoofer
Need program to make speaker work
Windows has a built in sound command )go to control panel and pick sound.
press play to emit a sound.
Your speakers need to be connected to the headset set output on the computer, but may not be powerful enough to drive the speakers on their own. In this case they need an amplifier.
Mar 07, 2010 | Koss Audio Players & Recorders
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
213 people viewed this question
