Question about Ovens
Baking function & Oven cleaning stopped working. Broiler works fine
  • horst weber Mar 13, 2011
    Manufactured by Electrolux Home Products,
    Frigidaire Model FGF366BCA
    Serial # VF23403426
    CGA-IR58 1995
    Household Apl.
  • 4,323 Answers
Hi
The issue seems to be with the bake element going bad however, please post back with its manufacturers name and model no. for further assistance.
Daniel
Posted on Mar 11, 2011
  • Daniel Scott
    Daniel Scott Mar 13, 2011
    Hi
    Please check the wiring to the temperature probe (Part #F37). If wiring is fine then make sure there is continuity to the temperature probe. If the probe seems to be fine then you would need to check and replace the oven igniter (part #F19 ).
    (1) UNPLUG OVEN FROM WALL.
    (2) Remove floor of oven
    (3) Remove large metal strip underneath oven floor (2 screws)
    (4) Removed oven igniter (2 screws)
    (5) Check the wiring to the igniter, if wiring looks fine then use a multimeter to check the current to the igniter lead. To check the current use multimeter on Amp setting & check if 3.6 amps or greater is present during ignition, if not then replace the igniter.
    (6) Before replacing mark the wires of old igniter.
    Hope this helps... Please post back if you need more information.
    Daniel
Frigidaire Model FGF366BCA range Problem: Baking function & oven cleaning function stopped working, (broiler works fine).
I used the self clean feature on mine and found that it got so hot that it burned out the sensor and ended up with the same symptoms you are describing. Had to have the sensor replaced. DO NOT USE THE SELF CLEAN
Mar 11, 2011 | Ovens
Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Jun 02, 2010 | Maytag CWG3100A Gas Single Oven
Oven won't heat or clean but broiler works
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
