I am having problems printing images. The images are 5x7" in the image window, but when I print them they are printed 8X10." I am using GIMP 2.4.6 and my printer is an HP PSC 1200. The printer works OK with all other programs. Thank you for your help. Ray
  • 42 Answers
Before giving print command, Ctrl+P>scaling: paper size>properties>paper size: OK Try
Posted on Mar 15, 2011
Print set up in the program
You do not specify what Epson Printer you are using. I have an Epson WorkStation. The Document Format in the Principal (Main) tab of the printer parameters lists among other format, a personalized (custom) format where you can choose the dimensions in mm or inches.
Nov 22, 2013 | Arts & Letters Arts and Letters Express
Setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Nov 30, 2012 | Nikon D3100 Digital Camera
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
How to enlarge scanned photo.
Set your scanner to scan at 600dpi.  That will give you a 8x12 image at 300dpi (print quality- your image never needs to be more than 300dpi).
Then use your favourite image editor to crop the image to 8x10.  If you don't have a favourite image editor, XNView (free) will do it:
http://www.xnview.com/
-Open the image in XNView
-Right click on the image, select "Set Selection Ratio --> 5:4"
-With your left mouse button, drag a square on the image...this will automatically scale so it chops the unwanted 2" off
-When the square is selecting the bit you want to keep, select "Edit --> Crop"
-Then we need to change the image from 600dpi to 300 dpi:
-Select "Image --> Resize"
-Uncheck the "Resample" and "Keep print size"
-"Keep ratio" should be checked
-Change the 600 in the "Units" box to 300; the setting unit should be "Pixels per Inch"
-Print
Mar 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
When I print pics off my pic file, the pic comes out in a mirror image? I am using a HP Photosmart 3210 All-in-One Printer. Also when I try to print 4x6 pics from my files using proper HP paper, it tells...
When you go to print something next time, click on Preferences on the Print window. Click on the Advanced tab. There should be a Mirror Image choice and it probably says ON. Click on the ON and change it to OFF with the drop-down menu. Click OK. That should correct the mirror image problem.
As for the paper, I have a hard time printing on 4X6 paper too. Seems to be a common problem with HP. If you would like to accept the mirror image solution and post a separate on, you should get another expert to help you.
In the meantime I will try to research it further.
Thanks for using Fixya.
Dec 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I need to make copies of my little brothers highschool football pics to send into the coaches at colleges, i try to scan the image of a 5x7 to 4x6 photo paper but it ends up cutting the image in half...
The images need to be re-sized. It's important when re-sizing to keep aspect proportions since a 5x7 print is a vertical or portrait print and a 4x6 is a horizontal or landscape print. Therefore, when re-sizing if you check off keep aspect ratio, you may get either 4" tall or 6" wide but not both or you'll stretch the picture distorting it. Picasa by Google is a good and easy to use photo editing program that should suit your needs and is a free download. Picasa Best of luck with your project and please post back with any other questions.
Greg
Nov 08, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Sizing the photo
Unfortunately, the P400 seems to have its own set of sizes. The printer will give a print close to the size selected. (This is really noticeable with the perferated psper.) The situation is no different with the P440.
Sep 03, 2006 | Olympus P 400 Thermal Printer
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
