Question about VIA P4MA Motherboard
I have motherboeard p4v845 its give me ound cant stop i try to change my Ram and i am sure its work and try to change cbu and VGA all work on another M.B but i have button in my M,B its 10 button exactly 5 button on and 5 button off
  • Brian Sullivan
    Brian Sullivan Mar 11, 2011
    what is the OUND
  • dont_ask20 Mar 11, 2011
    i disable every thing from M.B
    its just have power cable now and van for cbu nothing else
  • VIA Master
  • 27,725 Answers
If OUND is sound
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps don
Posted on Mar 11, 2011
Monitor does not work
IF your monitor stops working then first check your RAM if that is working then try change your VGA card then if it's not working then change the VGA cable of your monitor ..
Thanks
Apr 01, 2012 | Polaroid Televison & Video
Acer aspire ax1700-u3700a. The dvi port has stopped sending signals to the monitor but the vga port works. I use the vga port but the computer sometimes gives blue screens then strats back woring normally....
I can see you do have two issues here.Let us first fix the DVi port.Please see follow the steps below.
1. Please check video configuration by looking it up on the PC control panel.
2. Please make sure you choose the both DVi and VGA port by simply placing "tick" on the box.
On your second issue.Please follow the steps below
1. The "blue screen" normally comes up if you a faulty VGA cable or the connection is somehow loose.Please check if it is properly plug-in.
2. If the problem continues,I would suggest please contact the manufacturer or the store where the
item was purchase
Sep 04, 2011 | Acer Aspire AX1700-U3793A PC Desktop
HELLO, I HAVE A DELL MOTHERBOARD FOR DESKTOP COMPUTERS but the board is not responding at all the sound is not responding also the vga and the sound is not responding i have tried all i can to bring this...
try to unplug all extra devices and all RAM use one ram to test and see if it will boot could be bad ram also try to make sure its connected fully and properly good luck.
Mar 03, 2011 | Dell Refurbished: Desktop Motherboard...
Iam having a problem in my toshiba satelliate x205 sli1 it want start up it only gives me 3 bippes and no screen i cant see anything i removed all my rams and it still wan't run and don't even give any...
The beeps may be from the ram memory ..remove them and use one at the time and see if you get at least the devices or the logo on the screen ..the idea is to see if it is a ram issue or a video card ..
I think it may be the ram ..but ..the fact that it does nto show anything on screen is odd..usually even if ti is teh ram memory it shows a splash screen or so ..
If trying ram one at the time (in case of multiple modules ) does not make a difference ..you may try to see if an external monitor works ..This will eliminate the dead display ..
In the last case you should see what options have for a new video card ..the issue with this is the card may be on board ..and not having space for another one ..You may need to change the motherboard ..let me know what you've done ..and how it behaved..
Dec 10, 2010 | Toshiba Satellite X205-SLI1 Notebook
Getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Dec 26, 2009 | Asrock P4i65G Motherboard
No vga why? matsonic NS9147C
change the ram then try other wise check the mother board
Oct 10, 2009 | Computers & Internet
Will not start up
Check Ram or VGA two things that stop system from booting up , remove all PCI cards just leave vga card if u have extrnal one and then try removing RAM and then re install it try changing ram if problem persists lemme know and pls elaborate ur problem does it have power does it beep or what
Feb 21, 2009 | EliteGroup KM400-M2 V3.0 (KM400M230)...
Monitor turn dark frequently
it sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Feb 11, 2009 | Acer Computers & Internet
VGA
in some models laptop they dont allow to change the occupied memory for vga. so u cant changing. this is shared from your main memory (ram).
Oct 21, 2008 | Acer TravelMate 4150LCi Notebook
VIA P4V845 CHIPSET MOBO FOR iNTEL p4 CPU PROBLEMS
Hi, USB issues - Probably the BIOS. Have you checked the BIOS version? VIA P4V845? Also I get the impression that P4V845 have 2 versions, SX & SM, that it is an Intel chipset based mb and not VIA and that it was probably by one of the OEM vendors for Pc Partner. In any case, should you want to flash/update your BIOS, this might be of help to you > http://www.wimsbios.com/phpBB2/topic8315-15.html Good luck and kind regards.
Aug 29, 2007 | VIA P4MA Motherboard
VIA P4MA Motherboard Logo
52 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
