Question about Video Game Consoles & Games
Screen freeze followed by three red lights - Video Game Consoles & Games
Don't worry this happens to me all the time. justt turn off your game system and then turn it back on
Posted on Jul 31, 2008
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Screen freeze.
two work-around methods for those consumers who are experiencing the "freeze" issue: 1) Remove or disable the HDD
or,
2) Load three different Xbox 360 games to the main title screen of each game then load Major League Baseball 2K6 on Xbox 360. All three Xbox 360 games must be completely different before loading Major League Baseball 2K6.
Dec 25, 2007 | Microsoft Xbox 360 Console
Picture freeze and pinstrip on the screen
When a Microsoft Xbox 360 console experiences a "general hardware" failure or "core digital" failure, three flashing red lights appear (known as the "Red Ring of Death") around the power button, in lieu of the four green lights indicating normal operation. Warning signs may include freeze-ups, in which the screen has strange, spontaneous graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, the sound is frozen and changed to a strange, static-like sound, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the general hardware failure occurs, when the user attempts to turn the console on, and the three red lights are seen and the console will not function.
this sounds like it will error e74 which will need a reflow
but dont overheat with a towel as this will cause more problems
Mar 07, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
I have three red lights came during set up
The three red lights error is caused by overheating in the Xbox 360. Earlier models are particularly prone to this error. To solve this, do the following:
1. Call up Microsoft, tell them your problem and serial number of your console
2. If you are eligible for a free replacement, bring it over to the Microsoft service center
3. You should be able to get your replacement within a week or so.
Please note that Microsoft has extended their warranty to include older models even if they are already out of warranty so you really do not have anything to lose by calling them up.
NOTE: Please rate our help to keep this free service online.
Dec 21, 2009 | Microsoft Xbox Console
Three red rings flashing
if it is red(or darker orange) you have the three rings of death most of the time that means to send your x-box back to the manufacturer. but call Microsoft first.
Apr 26, 2009 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
XBox 360 freezing- Not what you think
Your system is headed for the dreaded red ring w/ three red rings. My system started doing the same thing just before this happend. If you have a service plan with it i would suggest returning it and getting a new one.
I tried all the there little tricks as well deleted everything off my harddrive all that good stuff i think it made mine worse. Cuz after all that i turned it back on and bam three red lights and no picture or sound.
Nov 28, 2007 | Microsoft Xbox 360 Console
Game freezes after 5-10 mins play time
if when it freezes it has a kind of checkerboard pattern, then it is what happens before the three red lights of death, try the eraser trick posted by Carl26
Aug 29, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
