Question about Canon Office Equipment & Supplies
Canon iP90 pixma printer: Black ink print head jets blocked up....Suddenly...not gradually black print quality has plunged.... head cleaning and deep cleaning procedures make no difference....Cartirdge has been replaced..... the print head check shows color jets are fine...black is afwful and print quality is awful Help??
  • 2 more comments
  • wcwdds Jul 31, 2008
    Yes: I did a print head alignment routine...I have been all over the maintenance page and tried all fixes available..... So for my $9.95 what other glowing comments might you have to help unclog my black print nozzles??
    Where do I invoke your satisfaction or money back guarantee? I thought someone might actually have a solution...but anyone with a brain, and I have one, can say...."Well maybe you need to replace the print head" Maybe I do, but if that's the solution I'm not satisfied and would like to be diredted to how I get my $9.99 back and reposted to my paypal account....
  • wcwdds Aug 02, 2008
    Didn't fix my problem, but I finally did get communication from someone who sounded like he knew what he was talking about...So.................done!!
  • Anonymous Mar 27, 2014
    Sometimes my print head makes a funny sound or a print job will stop in the middle.
    Guru:
  • 859 Answers
Sorry you are having trouble getting help. You can exit this thread anytime and you'll be prompted and or receive email to nominate the expert with the best solution. At this point you can invoke the unresolved money back guarantee.
In your case, this comes up a lot and Canon does not offer out print heads, its a factory fix, which is weird as most of us can get them for the other printer makers.
One problem does come up is if you have been refilling your black or buying refilled ink cartridges then this does happen all the time because the pigment is not small enough to Canon standards than the nanometer holes in the printhead.
Assuming you've been using the Canon ink and this has happened. You have used the machine beyond is know MTBF or Mean Time Between Failure rate. This would explain everything and your solution is to get another machine, preferably one where you can replace the print heads in the future. So that leaves out Canon.
In summary, exit this thread, when prompted choose unsatisfied or whatever it is they putting in front of you now, or wait for the email and then do it. You can also contact Fixya.com customer support and do a full write up, but copy and paste the url of this thread first so FixYa can take note of who was failing you. Sorry I didn't get hold of you earlier and give you a straight answer.
Regards,
Worldvet
Posted on Aug 01, 2008
  • 426 Answers
On the cartridge bay remove the foam pad and clean in a utility sink as it will be very messy, use alcohol for faster drying time.... make sure it is 100% dry and replace also check the area on the cartridge holder where the head goes to see if there is any gunk there, then clean the bottom of the cartridge bay with rubbing alcohol
another thing you will want to inspect is the control contacts on both the cartridge and the holder
hope this gets you 1 step closer to resolution
~Lee
Feel free to contact me at lee@whypayforhelp.org
Posted on Jul 31, 2008
  • Lee N.
    Lee N. Aug 01, 2008
    has this helped at all? if not let me know and i would be happy to work with you, Please dont rate the answer unless you are sure that i cant help :) ... what changes have you had since you have tried various things?
  • Canon Master
  • 6,487 Answers
If that's the case you may need now to replace the print head of this printer because it seems you have problem with it..
Good luck..........
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Did you also try to do a print head alignment on your printer.., you can do this option also on your printer utilities.
  • micromaster
    micromaster Jul 31, 2008
    Clogged...? If your printer cartridge is clogged and you're certain that there is ink left in the cartridge, you can sometimes manually force the clog out. Wrap some paper towels that have been dipped with a cleaning solution (we recommend isopropyl alcohol) around the cartridge and bang it against a hard surface. The force of the impact should knock the clogged ink free from the ink nozzles, allowing your ink to flow freely again.
We are trying to get our iP90 printer to print. We have cleaned the print head, replaced both black & color ink. We have done a deep cleaning several times, cleaned with alchol & cotton q-tip....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 04, 2011 | Canon PIXMA iP90 Mobile Printer
I have PIXMA iP90 printer but having problem of not printing blank test,I mean if i change the text colour to blue or any different colout it prints but not with black ink
This seems to be a comon problem with canon printers the black head is either dirty or needs to be replaced. canon should look into this
to clean heads use rubbing alcohol, cotton swab
put some rubbing alcohol on the cotton swab and gently rub the black portion of the head until it is clean
Mar 06, 2011 | Canon PIXMA iP90 Mobile Printer
IP90 won't print black. Replaced ink, deep cleaned heads, etc. Will print color, but not black.
You probably need a new printhead, but there is also a new update for that machine to help clean the black part of the printhead. QY6-0052-000 is the printhead #
Sep 24, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
IP90 stopped printing black
if ink is ok than have to change print head for black cartridge
Dec 16, 2008 | Canon PIXMA iP90 InkJet Printer
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
Canon i90 not printing black ink
You may be able to save the unit by cleaning with a qtip and some Fedron. Fedron is designed to clean platens and parts in printers and typewriters (it's original use). You can do a search on the web for locations that carry Fedron. Be extremely careful around any plastic parts becasue Fedron will eat/melt most plastics.
Jun 08, 2008 | Canon PIXMA iP90 Mobile Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Does not print black...
I have had this problem with the Pixma ip90. My machine did not like generic ink ie NON Canon. The ink had clogged up the nozzles. It was only when I put in genuine ink and cleaned and cleaned that I slowly rectified the problem.
If this does not work you may need to replace the printer head.
Good Luck
Mar 16, 2008 | Canon Pixma MP800 All-In-One InkJet...
94 people viewed this question
old marine
old marine
