Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
My vx510 dual comm reads data wire disabled. how do i enable it?
  • Mustafa Feb 05, 2012
    Did the solution posted on thiis question work. I have the same problem. How do you get the COM config file?
  • 42 Answers
Hi,you need to download the config file with settings of your COM then it will work.
psoftware109@gmail.com
Posted on Mar 23, 2011
  • psoftware109 Feb 07, 2012
    Just to clear, you want to enable COM setting in Vx510 to read and view the data/logs on your PC?so it is possible.do you have the SYSMODE password of your Vx510?
    Send your requirement to: psoftware109@gmail.com
Cannot connect
You need to give more info to work with. Have you tried each of the numbers as primary contact? This problem sounds like the unit is trying to connect with initial number, timing out and trying secondary number. This would account for processing delay.
Jun 28, 2014 | VeriFone VX510
Need to set a VeriFone Vx510 to Dial Primary from the start.
Verifone programming is different between countries and even between versions. In New Zealand the setting for internet or dial comms is in UTILITY/COMM CHANNEL. It will have a setting for IP, or DIAL, or IP/DIAL if using both where it will try internet and then use the dial if the internet is down.
Jan 18, 2014 | VeriFone VX510
I need a VeriFone Vx510 to start with Dial Primary first.
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
VX570 Credit Card Terminal (Dual Comm DCSC)... problem
You need tamper removal software for your Vx pos.
Feb 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Veriphone "Bad mac"
is your verifone you are talking about is a pinpad 1000se or the creditcard machine (VX510, VX570 etc.) and bad MAC (message authentication code) and i believe if the machine is not encrypted right or the encryption was errased for some reason, bad mac will appear. I've seen some of bad mac error together with tamper error on VerifonePinpad because the battery is going bad. Replaced battery and load the encryption, pinpad works again. Hope this will help you or call (775)358-2922 look for randy and maybe we can help you further. thanks
Nov 01, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Verifone vx510 missing msam card and ethernet doesn't show a connection when plugged into a modem
Eternet/internet model do not use the SIM card. Please advise what is the P/N on bot label and I will advise.
Aug 25, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
Verifone VX510 Terminal
If you cant use analog lines then you have a problem..What you need to do it replace the comm equip. to a DUAL COMM with IP services.. That should fix your issue
Jan 04, 2009 | VeriFone Omni 3700
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
699 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
