Question about Franke Coffee Makers & Espresso Machines
Evolution 2 step poor crema, shots too big
My shots are about 1.3 oz and I have little crema. What should i do to fix it
    Problem Solver:
  • 5 Answers
What bean type are you using? Do you have you own bean grinder? You should try diffrent settings on your grider. I think you should use a more fine grinding setting. It should take around 25sec for the espresso to flow.
Posted on Aug 02, 2008
100 grams of fruit equals to how many cups?
how big are the cups ?
I went google and typed in --how many grams to a cup--- and the following information came up
dry goods
1/2 cup==170 g==6 oz
2/3 cup =227g=8 oz
3/4 cup =255g=9 oz
1 cup =340g =12 oz
reference
dish.allrecepies.com>cup- to -gram-conversions
May 11, 2017 | Office Equipment & Supplies
Dispenses very little CREMA. Is there something to adjust?
Rule of thumb - espresso machines deliver a shot of coffee in 25 to 35 seconds.
If there is no crema and the coffee comes faster:
  1. There is not enough coffee in the portafilter (7 grams per shot).
  2. The coffee is not tamped enough (about 30 lb pressure on the tanmper handle).
  3. The grind is too coarse.
If the above does not "fix" the crema problem, post again and include make and model of the machine and type of portafilter.
Good luck.
Apr 27, 2015 | Coffee Makers & Espresso Machines
I have 8 oz. of chlorhexidine gluconate, i would like to dilute it to .12% solution. how would i go about doing that?
You would need a container that's at least 266 2/3 oz so it can hold the original 8 oz and 258 2/3 oz of water (a little more than 2 gallons).
Feb 17, 2014 | Office Equipment & Supplies
I get lots of watered down coffee. It brews 3/4 cup but it is so watered down. We have descaled etc. I want a thick expresso like taste. This is on a large cup setting Help?>
HI
When you run a lot of water through just a little coffee it gets water down. Try making 2 meduim cups instead. When they make espresso its 1 tablespoon to 1 oz of water. Your running 6 oz of water through the same amount of coffee, and its going to be weak. Program you buttons for 2 shots to fill your cup and it will be pretty strong.
Jan 25, 2011 | Gaggia Syncrony Espresso Machine
At a farmer's market you buy 6 3/10 pounds of red onions and 4 1/3 pounds of yellow onions.What is the total weight of the purchase?
If you don't have a calculator to help you with the division by 16, here is a list of all the decimals relating ounces to a pound:
  • 1 oz. = .0625 of a pound
  • 2 oz. = .125 of a pound
  • 3 oz. = .1875 of a pound
  • 4 oz. = .25 of a pound
  • 5 oz. = .3125 of a pound
  • 6 oz. = .375 of a pound
  • 7 oz. = .4375 of a pound
  • 8 oz. = .5 of a pound
  • 9 oz. = .5625 of a pound
  • 10 oz. = .625 of a pound
  • 11 oz. = .6875 of a pound
  • 12 oz. = .75 of a pound
  • 13 oz. = .8125 of a pound
  • 14 oz. = .875 of a pound
  • 15 oz. = .9375 of a pound
Jun 29, 2010 | Core Learning Fractions Step-By-Step...
Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
Apr 11, 2010 | Gaggia Evolution Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
2-cup won't work
you can try descaleing it again ,then go into
the factory reset program and reset it , I had a
similar problem this fixed mine
Dec 26, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
138 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
