Question about Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch
I have a tag formula 1 with a G10 711 movement. New G10 711 have a different size date ring. How can I (I am a watchmaker) find the correct movement?
Remove dial - use engraving tool to remove 3 plastic knobs to remove calendar wheel. replace calendar wheel with old one then heat a small drill to remelt plastic in the 3 holes.
Posted on Oct 23, 2012
  •  Michael
    Michael Oct 24, 2012
    I actually found a replacement movement.
  • 10 Answers
SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
Posted on Oct 10, 2009
  • 2501 Answers
SOURCE: Tag Heuer Formula 1 with alarm WAH111A.RWV3350
You can find the instructions on the Tag wed site (www.tagheuer.com), select "watches" then "formula 1"
then "man" and then the model of your watch.
On the right of the page is a small menu,select "user manual"
Posted on Feb 10, 2010
  • 2501 Answers
SOURCE: cannot pull the knob out, to change the date and
Some watches need to have the crown unscrewed.
Try turning it anticlockwise then pull out.
If this doesn't solve your problem, go to the TAG site "tagheuer.com" and find your nearest dealer.
Posted on Mar 08, 2010
genebur2
  • 63 Answers
SOURCE: how do i change the date on my tag heuer formula
You change the date the same way you change the time. The only difference being pull the crown out 1/2 way to the first click instead of all the way out.
Posted on Oct 19, 2010
Testimonial: "Thank you very much!"
  • 2501 Answers
SOURCE: I don't know how to
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Posted on Feb 01, 2011
The scond hand on my tag formula 1 has stopped and wont resest,but the watch still works with the time. What could the likely problem be? Could it be the battery? or could it need servicing?
Sean, This watch has a disposable movement(guts). That means the battery is the only part that can be replaced. The thing is glued together instead of screwed. Take it to a watchmaker that can get the replacement movement from Tag as the ordinary movements out there are different from the genuine Tag movements. Date wheels specifically are different. Anyway, a professional watchmaker, not a jeweler or store clerk please, will be able to tell you if that is the correct course of events to take. Probably looking at 200 to 250 Michael, Watchmaker to the Stars!
Mar 17, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How do i change the date on my tag heuer formula 1? i know how to change the time. I went to change the time and in doing so it changed the date. when i went backwards it would not change back
Oct 19, 2010 | Tag Heuer Formula One
The date adjusts at 1am. any solution? thanks
mcdevito75 here, That sounds about right, each watch is slightly different, some watches, have the date change at 10:30 PM and some at 11:00 PM, and if your Tag also has the month or day to change along with the date, this could account for the date changeing kind of late. I don"t think it"s anything to worry about.
Aug 13, 2010 | Tag Heuer Formula 1 Date Quartz Stainless...
Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Mar 25, 2010 | Tag Heuer Automatic Chronograph Series...
Cannot pull the knob out, to change the date and time on ny TAG Heuer Formula 1 CAC1111-0
Mar 07, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How can i make the date of my tag heuer formula 1 change automaticaly?
to 200 m (660 ft).
(normal position).
Oct 10, 2009 | Tag Heuer Formula One
I need to change the bezel on an older Tag Formula 1
I'm sure any watchmaker can do it for you. I've had one pop off an old one for me an replace it with a slightly used one he had. I would like to replace that with a new one. They're available in the UK, but they're pricey. Ebay is an option.
Nov 24, 2008 | Tag Heuer WAH1112.BT0714 Formula 1 watch
Early tag heuer professional 200m wrist watch
nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
Jan 25, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch Logo
215 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
