Question about RELIANCE ELECTRIC WATER HEATER
I have a Reliance 606 water heater that no longer provides hot water. Any ideas?
  • 604 Answers
The heating element has most likely burned out (if its electric) if its gas then look to see if it is lightinng. if electric, the element is easy to replace and not very expensive.
Posted on Mar 11, 2011
If you have an Ohm meter you can test the elements (top/bottom) to see if they are good without blindly replacing them. With the POWER OFF... put the two probes on each lead of the element. If it reads between 10-15 ohms (depending on the wattage of the element) they are good. You may just need to reset the little breaker above the first element. When I get power surges from electrical storms it's the first thing to trip.
Posted on Jul 26, 2012
My reliance 606 electric water heater keeps tripping the breaker. When it is reset the water gets real hot and trips again, then no hot water. Help!
You water heater most likely has a shorted heating coil, don't run it like this, call a service technician.
Nov 10, 2016 | Reliance Water Heaters
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
WHERE IS THE ANODE ROD ON A 606 RELIANCE HEATER
It is the 1" or 11/8" hex nut on the top of the water heater some where near the supply line. As for the anode rod it could be either magnesium or aluminum depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and type of water.
Sep 23, 2014 | Reliance 606 Series 40 Gallon Electric...
No hot water
It is probably the thermostat. I would suggest replacing that next.
Feb 24, 2014 | Reliance & 40 Gal Electric Mobile Home...
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Where is the anode rod in a 606 electric reliance hot water heater--is it magneesium or aluminum
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water.
Feb 05, 2011 | Reliance & 50gal Electric Water Heater
How to change a thermostat on reliance 606 hot water heater. water is getting too hot and there is no sediment build up. also water heater is only 4.5 years old.
I wrote a page for changing water heater thermostat.
The photos take you through step-by-step
I recommend replacing both upper and lower thermostats so it eliminates thermostats as possible cause if water heater keeps overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
The Reliance 606 manual shows your water heater uses generic upper and lower thermostats from hardware store.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Likely the thermostat will solve the problem:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Nov 09, 2010 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
468 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
