I was moving the tv and forgot to unplug the cable and the connector in the back of the tv broke off. What can I do?
  • jenny walsh Mar 12, 2011
    Yep I believe a new tv is in order! Thanks for your help!
  • 718 Answers
You will have to replace the board that the connector is on. You did not give a make and model so I can not give more information.
Posted on Mar 11, 2011
    The model isToshiba 32A41 and its over 10 years old
  • marionbagget Mar 12, 2011
    140lbs crt analog tv.
    You have only two 'video' inputs (svideo/RCA and component/RCA) and an RF jack. You did not say which connector was broken so if it was the the RF jack (cable,arntenna) then this leaves you with the necessity of using 'creative connections' -- which usually means routing your satellite dish signal through the VCR. That the only no cost solution. The cost to repair this crt based set would be more than a new LCD which is what you want !!
The part were the cable plugs into tv what is the name of that parts movers forgot to unplug and broke it off tv modle pcl542r
james8959125,
See my tip at http://www.fixya.com/support/r6250309-replace_tv_tuner_f_connector for the procedure to replace your "F" connector and where to get the parts.
Thanks for using FixYa and for the great rating,
hardrocko
Apr 26, 2011 | Samsung PCL542R 54" Rear Projection...
Coax connector is broken off-how can i replace the connector?
You can pick up a chassis mount F connector here...you will need someone with basic soldering skills to replace:
http://www.electronix.com/rca-connector-p-13010.html
Oct 21, 2010 | Samsung TXG2548 TV
Cable input jack bronken off
Actually I just repaired one of these "similar" units. If you remove the backing of the tv, unpluged of course, Theres a panel facing you if you are looking at the right side of the TV. This panel pops off easily with a light prying motion all around. You'll see where the connector broke off and can solder it back together with a small pin type tip. Solder the center pin to the center probe first,hold in place with needle nose pliers. 2 people are better than one at this. Then lay down agood bead of solder around the perimeter of the connector. Clean up any solder that may have dropped and put it back together, you'll be ready to go in about one hours time. Let me know how it goes!!!
Jul 25, 2009 | Orion STV2763 27" TV
Broken cable connector in the back of JVC tv
if the remaining piece was not part
of the PC board , which is light yellow
theres a good chance with a soldering iron
and a new female coax from radio shack
you could do it . or pay a shop 75.00 to
reinstall one for you.
Jun 30, 2009 | Televison & Video
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
VCR/DVD prongs broken off in TV
unplug the tv then try to drill a real small hole in the broken off part of the cable that is inthe tv, then take a sharp pointed screw and try to thread it into the hole that you drilled if able to get it started then pull out on the screw to see if it will come out. If not able to do it this way you will have to take the back off and some of and see if you can push the broken part out from the inside. Be sure to unplug your tv from (AC) so you dont get hurt. If that dont work then u probley willhave to take to a shop to get fixed.
Feb 20, 2009 | Zenith C27A24T 27" TV
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Tv repair
Yes, it is worth repairing. Replacing the F connector is a very simple thing, and as long as nothing was forced into the hole left by the missing F connector, the repair should run about $40.
Sep 10, 2007 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
