Asrock4coreDualSata2 is destroying AGP cards. Two so far. Third (old) card working for now. Cards boot and load WindowsXP then go black. AGP voltage problem? New board solution?
  • 197 Answers
Get a higher power supply as far as amps, it sound like that if you have already been throght two cards theres is not enough amps running
hope this helps
tazman
Posted on Jul 31, 2008
Agp cards not working
ok hmmmm maybe it only except 4x agp? is it very old? maybe the slot maybe burned out? do you have enough power source to run the card? i cant think of anything else.. good luck. my agp card did the same thing when the power source burned out. some day i would get nice veiw someday a dark screen. i though restarting would help and eventually the power source burned out.
Jan 21, 2010 | Intel D865GLC Motherboard
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
Compatible Cards
Mac G4 supports only AGP cards today almost all the cards come in PCiE format. Your best bet is a 4x AGP card any brand will do as long as it is AGP 4x.
Feb 10, 2009 | Apple Computers & Internet
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Uable to install driver without screens going black
Its like putting rollerskates on your dog - you maybe be lucky to get him walking faster and such but what are you trying to prove? just be normal and your pc will behave fine
Apr 11, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
GRAPHICS CARD
The P5PE-VM has an AGP 8x expansion slot. So AGP 8x graphics cards would be compatible. AGP is old and got replaced by PCI Express. But you can still buy AGP cards. the Nvidia 7800 is the best AGP card you can get, because Nvidia stopped creating the technology for AGP cards with this one.
Apr 08, 2008 | Computers & Internet
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
Card seems to be defective - slow, reboots, fails on resolution change
If Windows is continuously loading up to 800x600 then your drivers are not being installed. Are you using the the 169.21 Nvdia Forceware package? What OS?
Jan 09, 2008 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
Xfx 7950gt agp 512mb
Hi, if you have got the drivers for this v/card then load them while you have your present one in place, if you dont have the drivers then go to the manufacturers website and get them . when you have loaded the drivers then check if you need to enable any changes in your bios. Change the card and if it is functional then you should have solved your problem. A card that advanced needs drivers far greater than you would find in XP. Regards mistyman
Aug 20, 2007 | Pine Technology XFX GEFORCE 7950 GT 512MB...
AGP Card Problem (nVidia MX 4000 128MB)
you will have to set the agp card as the primary graphics device in the bios, either press F2 or Del on boot up and in advanced cmos settings, look on the list for hardware or similair and you will see that the primary graphics controller will list as VGA, change this to agp and then save settings and exit, it should then boot as normal. The only other thing is if you have removed a graphics card previous to fitting this one and you have left the old drivers on your pc, this will cause conflict, so if this is so refit the old card and then uninstall the old drivers and then shut down the pc and refit the new one.
Aug 16, 2007 | Pine Technology GeForce Mx4000 (64 MB) AGP...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
