Question about Refrigerators
We have an Amana refrigerator with bottom (frost free) freezer drawer. There is ice build up inside the freezer on the back wall and food is not freezing. The refrigerator is about 6 years old. any suggestions.
  • 3,287 Answers
Your fridge is probably suffering from a defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating elementor 3) the defrost controller / timer. Items 1 & 2 will be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate.
Before we go further - check and clean the condenser coils on the bottom of the fridge with a vacuum. They may be clogged with dust and dirt. Listen for the compressor and fan - are they running? Since everything inside the fridge is warm and getting warmer - the compressor should be running to try to cool it. If left to run like this for a long time however, can cause the compressor to fail. This is usually a deal breaker for repair due to cost. if the fan or compressor isn't running - you should probably call a repair person.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it contacts your eyes. These reasons make me believe that this is a complicated DIY type job and really isn't a good one for a beginner or intermediate to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and parts markups can bring this repair up into $100 - $200 and up range, however.
If you can't swing that amount of money right now, unplug the fridge, empty the freezer (& fridge if needed) and completely defrost the the freezer. If you access the freezer coil behind the inside back wall, you can greatly accelerate the defrost process by leaving the freezer door open - or even faster still by directing a blow dryer at it. Once all the frost is melted, plug the fridge back in, allow to get cold & reload the freezer. Depending on how humidy it is in your kitchen, you can put off the repair at least a month or more.
When you do finally call, for service, have the freezer emptied & defrosted already - will save the defrost time by the repair person.
If you are comfortable performing this work, let me know and I'll get you more information. I hope this was helpful and good luck. Please rate my reply - thank you.
Posted on Mar 11, 2011
I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
Aug 13, 2011 | Amana Refrigerators
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Heavy Frost in the freezer
There are a few reasons for frost building up inside the freezer compartment. Refrigerators work like dehumidifiers collecting the moisture in the air inside and defrost is supposed to remove the moisture while defrost through a drain and then to the defrost condensate pan below the refrigerator. Ever notice how ice in freezer over time the ice cubes become smaller? Or food that is not sealed dries out. You either have one of three problems. Defrost drain blocked behind the rear wall in back of freezer, air leaking into freezer through the door seal and in your case the drawer seal and finally water possibly leaking into freezer from Ice Maker, Let me know, Thanks Sea Breeze
Jun 19, 2010 | Samsung RF265AA Bottom Freezer French Door...
Refrigerator is barley cold, still makes ice, condensation inside of frostless freezer
Hi: The fact that it still makes ice tells me the freezer is a zero degrees. When you said condensation in the freezer did you mean frost? If your defrost heater fails it will cause the frost free freezer to build up frost. The frost will build up and block the vent that supplies the cold air to the fresh food. The defrost heater is behind the metal wall at the back of the freezer, at the very bottom. A glass tube with a metal coil in it. The coil can break and stop the defrosting. Replace that. Use a hair dryer to melt the frost from behind the panel. All of it top to bottom. You need to remove all the frost to free up the airways. I hope this helps, Jeff
Jun 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge not getting any air, freezer is working
I have a Kenmore w/ freezer on bottom. The top vent in the fridge is ducted to the freezer and is supposed to blow air. Mine was not.
I removed all the frozen goods and took off the back panel (inside to unit) which had a little ice on it. Underneath the panel was a solid wall of ice......including the motor which is supposed to blow air up to the 'fridge. I'd bet a beer that is your problem as well.
The ice seized motor will not be harmed because it is resistance loaded.
The best part is with a blow dryer and some elbow grease...the fix is free! I hope it helps.
May 27, 2009 | Amana ABB1927DE Bottom Freezer...
FRIDGE FREEZER BUT FRIDGE STOPPED WORKING FREEZER WORKING OK
look on the back wall of the freezer is there snow? if so you have a defrost component out (timer, limit, or heater) the fresh food compartment gets cool air from the freezer so check for blocked air pathways the build up of frost in the freezer stops air flow so you will be cold on freezer side and warm on ref side
Apr 24, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
