Question about Brother MFC 240C All-In-One InkJet Printer
Printing blank pages I replaced all cartridges
  • 310 Answers
The problem is with the print head (is clogged) , try to clean 2-3 times if doesn't work you need to change the print head.
Posted on Mar 11, 2011
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
Jan 18, 2011 | Samsung ML 1210 Laser Printer
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Printer prints blank pages. computer screen shows ink in cartridges
screen shows ink but many of the times if the cartridges are dried up it will print blank pages.clean the cartridge head clogging manually and then try.otherwise replace the cartridges.
Dec 07, 2008 | Lexmark Inkjet Z517 Photo Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Jun 17, 2008 | Epson Stylus C60 InkJet Printer
Printing Blank Pages
If the cartridges are original, your unit needs qualified service.
Oct 23, 2007 | Samsung CLP-500 Laser Printer
Brother MFC 240C All-In-One InkJet Printer Logo
255 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
