Question about Sony DAVHDX265 System
Hdmi not working
My sony davhdx265 hdmi is not working brought new cord still not working hook my xbox to hdmi cord and it came on need to know if i am missing anything
You probably have to turn it on in the DVD menu/settings and set the correct resolution/output. I do believe these will upconvert to 1080P, a resolution your TV may not be able to display. Try 1080i or 720p, these are still HD resolutions. Also length of HDMI cable can be an issue, especially if over 6', while your Xbox may have a stronger signal.
Posted on Sep 30, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
How to connect DAV-HDX265 to xbox 360 and TV
Your HDMI cable handles both audio and video. If you would like a "one" source output you need to have a reciever that has multiple inputs with one output. You would then put your audio out from your souce device (xbox, tuner,record player...etc.) to the input of the reciever. Every device should have a different input. From there you would just switch your input selection to what you would like to hear. Let me know if you need a bit more guidance and I will get more detailed. The RCA connection (Red and White) are your stereo leads or (left and right) You will need the yellow one for video..it is separate.
Jan 19, 2013 | Sony DAVHDX265 System
I am trying to hook up my playstation3 to my my sanyo plasma hdtv I brought the HDMI plugs when i hooked it up I have no video and no audio what do I do to fix it or do i need a plug for each one of my...
If you would like both video and audio to output through the HDMI cord, make sure to go into the PS3's video settings and select HDMI output there, and also go into the audio output settings and select HDMI. This should make the audio come out of the TV's speakers.
If you're using separate speakers, such as a surround sound system, use a different audio output (such as the red and white component cords) and plug those directly into your sound system.
Apr 24, 2011 | Sony Playstation 3 (PS3) Console
Hdmi doesn't work
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Don't hold it to long or it will go on stand-by.
Also try reversing the ends of the HDMI
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Help
HDMI function works with all those components who have HDMI port in it. I dont know I made my point clear or not.
May 27, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Sony DAVHDX265 System Logo
126 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
