Question about Timex (T307S) Clock Radio
Lost my manual. How do I change time setting. I think I used to use one of the buttons on back but all writing worn off. thanks.
I have the same clock. Press and hold the time set button on the back of the clock, use the forward and back buttons on the top of the clock to select the time. once the time has been chosen, the clock will beep. your time is now set.
Posted on Mar 13, 2011
How do I change to fahrenheight from centigrade model 688r06
found this
On the front of the unit is 3 buttons directly under the LCD display. Use the lower left button market "Set" to do all of the settings, time, month, day, year, F & C, etc. There are 2 tiny buttons on the back of the main unit that is + or - and these move thru the changes on each setting. Hold down the "Set" button on the front until you see each item flash, then use the two buttons on the back to get the correct info you want, then push the "Set" button quickly and that sets each category. I hope this has helped you both? I've had mine for several years and lost my manual also but, after using mine for so long, I know how to do all the settings. The manual is not available on the web unfortunately.
Nov 18, 2015 | Measuring Tools & Sensors
Turn off alarm without key fob
First off, you need to know the PIN.
Setting the PIN is as follows:
Think of a five-digit PIN, and write it down. Think of this set of numbers as a password for starting your bike and disabling the alarm during those times when you don't have your fob.
Turn the ignition key on, then off, then on, then off, then on again. Then press the left turn-signal switch twice. Press the right turn-signal switch once, and the current PIN should appear in your odometer.
Be sure the first digit of the PIN is flashing. Enter the first digit of your new PIN by pressing the left turn signal to cycle through the numbers.
Press the right turn signal once to switch to the second digit, and select the correct number with the left turn signal. Repeat this process until your new PIN is entered correctly.
Press the right turn signal once, then turn the ignition key off to save the PIN you selected.
Now, how to disable:
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times (the 1st "3" of the PIN). Press right turn signal button 1 time (to "set" the code number).
4. Press left turn signal button 1 time (2nd number of PIN). Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Dec 25, 2013 | Harley Davidson Motorcycles
How do I set the date and time spamp on a Canon A490
Hello and Welcome to FixYa!
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 11, 2011 | Canon PowerShot A490 Digital Camera
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
How to set time Casio W-89H two button watch
Actually, the watch has 3 buttons -- "Light" being the 3rd one. Press Mode until a number in the time mode begins flashing. Then press the Light button to get it to the hour indicator. Use the 12-24 Hr button to set it to the current hour. Then press the Light button again to get it to the minutes section. Again, use the 12-24 Hr. Button to set it to the next minute coming up in the current time. Then push the Light button again. This will bring up the seconds indicator. At the precise time the minute you set before begins, hit the 12-24 Hr. button, and the indicator goes back to zero and begins ticing away. Then hit the Mode button again until the watch is in the current time mode. Hope this helps. I use Internet time to set a precise time.
Jul 17, 2009 | Casio Watches
How do I change the time
U have settings till 1 to 25. its written on the right side of printer the bottom of the buttons whats for. U must just read what is write on the display and in the settings change the time.
Mar 30, 2009 | OKIFAX 4500 Plain Paper LED Fax
Lost the controller for Pioneer rear projection TV
Try pressing the "Input" button the front of the set. That should allow you to change between the different inputs. The return button usually returns you to the previous channel you were watching - don't think it works for the input though. Also, depending on the model of the set you have, try downloading the PDF user or owners manual - it will tell you how to use the remote.
Jul 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Setting Time and Date on a Timex WR30M
1) Press and hold mode for about 2 seconds and then release. You will now be in the alarm edit mode.
2) Press mode once more and now you are in time edit mode.
3) Use the stop button to select what to edit, i.e. hour minute, etc.
4) Use the reset button to make the changes once you have selected the hour/minute, etc. that you want to change.
5) Press
Mar 07, 2008 | Watches
Setting the time on a Timex Data Link 851 Watch
You have to use the USB cable and do it through your computer. There is no way to change the time on the watch. Bad design.
Dec 31, 2007 | Watches
Change Date/Time on Canon Fax L350
Left the flap on the right hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Nov 16, 2007 | Canon FAX-L350 Plain Paper Laser
Timex (T307S) Clock Radio Logo
98 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
