Question about Wasabi Power ® Battery (BTRVBG260JWP) for Panasonic VW-VBG260GK
How long do you charge a Wasabi Power BTR-VBG260-JWP battery in it's mini rapid wall plug charger?
  • 604 Answers
The lights should change from flashing to steady or something like that, usually 1 to 2 hours is enought, depending on how deepley the battery was discharged
Posted on Mar 11, 2011
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
Canon zr85, battery won't charge
It sounds as if your battery is shot. If it does it with any battery then that's not the case, of course, but a Batteries Plus store can test it for you or you can just order a replacement from Amazon. I've had good luck with Wasabi Power replacement batteries from Amazon.com.
Apr 21, 2014 | Canon ZR85 Mini DV Digital Camcorder
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
I need a charger for my Samsung WB600. I somehow lost it. Still have the USB cable. Any suggestions?
The Samsung WB600 digital camera is also known as the Samsung HZ30W. (see the Samsung Product page.for accessories, manual, etc.)
pchpatti_5.pngpchpatti_6.png It uses the Samsung SLB11A Lithium Ion rechargeable battery. Several third-party compatiable chargers for this battery are available through retailers such as Amazon.com:
Add shipping costs for each.
An extra battery is usually a good idea, too.
Jan 22, 2011 | Cameras
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Hello, my godmom just purchased a Brand new Blackberry Curve phone.When the saler put the battery in the phone, it didn't power on and she said that the battery was not charged and that we had to charge...
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
May 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
Can a battery pack charger for a # VW-VBG70A work on VW-VBG260
Yes. all three batteries can be charged by the vsk0697 adapter. However, the vbg260 is three time as deep as vbg070 and vbg6 is even deeper, So the batteries may not fit on the camcorder or may protrude outside. These will fit nicely for camcorders like HDC-sd9 (mine). Panasonic recommends a wait-belt-carrier bag for these batteries with adapter plate plus cable to use with the camcoders to avoid the original design weight balance of holding the camcorders.
Feb 22, 2009 | Panasonic Video Cameras
Wasabi Power ® Battery (BTRVBG260JWP) for Panasonic VW-VBG260GK Logo
341 people viewed this question
Top Wasabi Power Cameras Experts
Are you a Wasabi Power Camera Expert? Answer questions, earn points and help others
