Question about Kenmore Kitchen Ranges
Incounter range allows heat to escape and damages paint on range. Can't get to model #. Range is 4 years old. Can send photo but damage occurs to 2d knob from left side of range. Jim
  • 604 Answers
Ranges don't change much, go to the sears store and try to find a unit that looks like and is appx the same size as yours. when you find it, have the sales person look up that model and find the parts diagram from sears parts depot. you should be able to purchase the seal that goes around the door for about 30 dollars or so.
Posted on Mar 11, 2011
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
My GE range is only 10 months old and has rust spots forming on the inside bottom, what causes this? This is also the second GE range to do this in the last 4 years. Are GE ranges known for this?
Rust spots will only occur after the finish is damaged or just simply fail.
This is not common for GE or other manufacturers. But I would not be surprised in the quality of workmanship is slipping for all manufacturers.
Oct 20, 2013 | GE JB705TTCC Electric Ran Freestandin 30...
Engine coolant level drops on Mercedes C180 2001 model
Loss of coolant is serious because if you allow your engine to overheat you can cause very expensive engine damage - thousands of dollars of damage (not hundreds).
The items that need looking at are:
- Radiator cap is old and faulty. This can allow coolant to escape and needs to be replaced every 4 or 5 years (sometimes sooner) with the correct spec cap - not any old product picked up at some auto store.
- External leak - you need to check all flexible coolant hoses and connections for leaks as well as around the water pump to ensure the WP gasket is not leaking
- Internal leak
The most common is a blown cylinder head gasket which can allow coolant to escape and to get into the cylinders and into the lubrication system. If getting into the cylinders you will see white smoke coming from the exhaust . You need to check the engine oil for coolant contamination as a coolant can escape into the lubrication system via a damaged head gasket. You also need to check the coolant for signs of oil escaping under pressure via the blown head gasket into the cooling system.
An internal leak can also be caused by a cracked cylinder head but if you have this condition are blown head gasket will have probably occurred around the same time.
Dec 27, 2012 | Cars & Trucks
I have an electric flat top range, it's about 4 years old and just within the last few days every time I use the oven it omits a very strong chemical odor. I have not been using it because it does not...
Hi, If it is the paint that is chipping on the bottom of the oven then that is where you are getting the smell. That paint is actually very important to keeping the heat inside the oven and not letting the actual cavity itself from getting too hot. I hate to say it but you will probably end up having to replace the oven. You can get a second opinion from a local servicer to give a definit yes or no. but from the sounds of it that is what you will have to do. Sorry, hope this helps.
Jan 12, 2011 | Maytag MER5775Q Electric Kitchen Range
Caloric Gas Range Model #355 19 years old. Is there a replacement ignitor available to replace the old one?
Being that your range is 19 years old it might be a bit difficult to find the correct igniter but not impossible. The model number that you gave is not giving any good results. You can go here http://www.repairclinic.com/Caloric-Range-Stove-Oven-Parts?s=b74a13c249 and look at these igniters to compare with the one on your range. You might get lucky and one of these could be a replacement that will work. Most local range parts suppliers are very helpful on locating hard to find parts but you may need to remove the igniter and bring it in so they can match it up in their catalog. You might also be able to find the correct igniter if you use the part number on the ceramic igniter housing to do a parts search with. Most 20 year old ranges use a standard "flat style" hot surface igniter but there are different OHM ratings for some igniters and this rating is important for you to match up correctly with your current igniter OHM rating or you could damage the gas control valve and/or the new igniter.
May 11, 2010 | Tappan TGF363 Gas Kitchen Range
Can a microwave listed as a countertop be installed over an oven or should an over the range type be installed?
over the range should be installed
they are desined to take the heat being over the stove will generate
as well as become your vent for the stove top
Oct 09, 2009 | Ovens
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Almond or Bisque Color the same??
Your range is almond. The AA at the end of the model number is the color code for almond. Paint on a range may be affected by high heat be sure to use one that is tolerant of high heat. Almond is more yellow and bisque is more white, not the same color.
Jan 02, 2009 | KitchenAid KESC307 Electric Kitchen Range
Amana Oven Issue
If you have an Amana range that allows heat to escape from the ranges/ovens when used in their intended manner and is causing irreparable damage to other components or the ranges/oven, including but not limited to, the units’ control board. This problem can discolor the units, diminishing their value and compromises the ability of the ranges/ovens to perform in their intended manner.
If so, this on going problem poses a significant safety risk to their users and property. I know many of you are frustrated and many of you have complained to Amana and have been told that, “There have been no complaints or that the problem does not exist”. Well they won’t be able to say that any more if the thousands of us come together as one and voice our concerns and complaints.
If you would like to be heard and possibly have your range replaced or fixed please send me an email of your existing problem along with your units’ serial number and model number and together we will be heard. vloredo@cox.net
Jul 22, 2008 | Amana ACS3350AS Gas Kitchen Range
Kitchen Ranges Logo
47 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
