Question about Rowenta Irons
HOW DO I REPLACE THE PLUG ON AN IRON ? - Rowenta Irons
  • 604 Answers
If your talking about the plug end, just cut the wire and buy a new plug at the hardware store, if you need a new wire, the its a different thing entirely. let me know what your really need to know.
Posted on Mar 11, 2011
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
Iron will not stay on
More than likely your power cord has a broken wire. Plug the iron in and mover the cord around. See if you can find the broken wire. Typically where the cord comes out of the iron and right at the plug. Or replace the whole cord. Your local hardware store, youtube, or menards can show you how. Very easy to do. I tend to stay away from home depot.
Sep 18, 2013 | Euro-Pro Shark GI490 Iron
Iron plug
Bit more information would be handy? whats wrong with the plug? is there just no power going to the iron? have you tried replacing the fuse? have you tried taking the wires out and making sure there is a strong connection between the wires and the screws? if your iron isnt turning on it may not even be a problem with the plug. it could be an issue with the motherboard in the iron
Jul 04, 2013 | Irons
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
Sparks when you put in plug
Do any other devices or appliances spark when you plug them into the same outlet? If so, you may have a wiring problem, and you should have an electrician inspect the wiring as soon as possible.
If the iron is the only thing that sparks when you plug it into the outlet, there may be a wiring problem inside the iron, or the ground wire may not be connected. Irons are not generally expensive; you should replace the iron for safety's sake.
Nov 29, 2011 | Irons
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
Damaged mains cable
it is betterr to get a sealed power plug with the nylon insulation for the iron with a 15 amps rating wire and plug.
open the unit and disconnect the wire of the damaged plug, remove and replace with the new one taking care to connect each of the wires to the correct position. The lead , neutral and the ground must be double checked before you switch on.
Aug 29, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Cord seem loose - iron keeps shutting off - jiggling cord gets it started again - need to do this to get iron going.
Try re-tightening the wires at the plug and on the iron, but if this does not solve the problem ,replace the cable.You should be able to get it from your local hardware.
Hope this has helped you
Please come back to me if you have any further issues
Aug 10, 2009 | Rowenta Irons
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Irons Logo
49 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
