How do I reset the clock? - Televison & Video
  • 604 Answers
Press either "menu" or "Setup" on your remote, there should be some options there, usually the clock is in the "initial setup" features, go there and look for time and date settings, follow the on screen instructions
Posted on Mar 11, 2011
How do I reset the time on my HHScott Inc Atomic Clock ?
An atomic clock should set or reset automatically. That's what an atomic clock does. Right now my clock reads 1:35 and the computer read 1:37. Go figure : - )
Nov 21, 2016 | Home
The atomic clock did not reset to daylight savings time. How di I reset it?
Depending on which country you are in (the UK won't reset for a couple of weeks yet), your clock will automatically reset when it receives the adjusted time signal. If your clock is not receiving the signal, try moving it near a window and away from any electrical interference, or it is possible that your battery is getting low and has not got enough power to receive the signal.
Mar 08, 2015 | SkyScan 86709 Atomic Wall Clock
How to reset wesrminister wall chime clock
If this is a mechanical clock, make sure the chime lever is set on. If quartz there is a reset button to forward the chime advance until it matches the hands.
Mar 19, 2013 | Seiko Mantel Clock
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Toyota Yaris 2009 Clock Reset
Check your owner's manual. Then try the other button? This is a new car, though. Try disconnecting the negative battery terminal for about 15-minutes to reset 'all'.
Nov 11, 2009 | 2007 Toyota Yaris
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
Honda VFR800 Fi 2000 W Reg LCD clock problem
The problem is usually a weak battery. When cranking, it pulls down the system so much that the clock resets. Try puting the batt on a charger and start the bike to see if the clock resets with a steady feed of voltage.
May 17, 2009 | 2005 Honda VFR 800
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
Resetting clock on go video dv1030 player
I found the manual for GoVideo and reset the clock.
Thanks!
Jun 26, 2008 | GoVideo DV1030 DVD Player/VCR
Outside temperture
After changing the batteries on the outside unit, remove the batteries from the clock for a few minutes, then replace them. This will reset the clock to 'talk' to the transmitter.
Nov 21, 2007 | SkyScan 86709 Atomic Wall Clock
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
