Question about Toshiba Satellite Pro M15-S405 Notebook
How to enable my toch pad in my laptop toshiba,i enabled it ,how to fix that
  • 624 Answers
SOURCE: HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE PRO M15-S405
Press the Fn and F9 keys, that should turn it back on. Let us know if that solve your issue and please dont' forget to rate this posting.
Posted on Feb 09, 2007
  • 2692 Answers
SOURCE: wireless device disabled
Go into setup routine and enable wi-fi.Save and exit. Usuall you have to press delete or some other key when first turned on,to get into the setup screens and BIOS.
Posted on Dec 27, 2008
rtrahan
  • 741 Answers
SOURCE: how can i enable the num lock on a toshiba laptop U305
On some laptops you have to hit the Fn + num lock..
Posted on Mar 29, 2009
  • 83 Answers
SOURCE: how to enable my bluetooth on my toshiba laptop
Most of the time when you go to Start - All Programs - Toshiba you will see Bluetooth. This will be there if you have the driver installed. Also, make sure that the Bluetooth logo is on the bottom of the laptop to make sure that your model was built with the Bluetooth chip in it. Sometimes you can also find the bluetooth icon on your taskbar and by right clicking on it you will bring up the "enable" option. You may also want to go into your control panel and see if the icon is in there. The shortcut to get to the control panel is "Start" key then press the "c" key. Hope this helps.
Posted on Oct 07, 2009
  • 6771 Answers
SOURCE: Toshiba Satellite.C655.enable.space.bar
Hook a external keyboard, if okay! problem with the laptop keyboard. Try a system restore and bring the computer back to a earlier time before this happened, just might work. The keyboard can be disabled from the bios setting I don't see how it can be done any other way.
Posted on Mar 18, 2012
My cursor on my laptop in stuck in the middle of the screen? my daughter i think my have pressed a few buttons?
You can re enable touch pad easily, some models of Toshiba has a switch between touch pad and space key, or you can enable it by pressing fn key and f9 together (or you can find near to it )
please vote for me if found useful ... Thank you
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Problem with mouse in my new Dell laptop
Touchpads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
Touch pad dosent work
Hi
I'm not sure please try pressing Fn+F9 (or try Fn+F8 or Fn+F7)
this should enabled/disable the touchpad.You also can enabled/disable it through a pointing device software.
goodluck,takecare.
May 21, 2008 | Acer Computers & Internet
Toshiba satelite M200 touch pad not work
saket,
try to find out if there is any button for you touchpad on the keyboard, if you found then press this and try.
If you did not find then try the following:
  • Goto Start -> Control Panel
  • Double click on mouse icon
  • Then goto Device setting, there you can find an option/button to make your touch-pad enabled/disabled. Make it enable and try.
Thanks
Iqbal
Apr 28, 2008 | Computers & Internet
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Feb 09, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
