Question about Vacuums
Hello, I have a Viking Topaz sewing machine, the top thread is visible on the underside of fabric, indicating a tension problem. I have cleaned the machine, turned it off and back on, rethread it numberous times and tried to manually correct the tension. but nothing helps. What am i missing? Thanks
  • Vacuums Master
  • 1,564 Answers
Thread, Tension, Needle.
Make sure your needle matches your application. example: heavy denim needs a heavy needle (90-100) instead of the "universal" needle that usually comes with a machine.
Also make sure that when you thread your machine that you have the pressure foot in the up position. Many machines release the tension discs in this position allowing for proper threading. Also make sure there is no fluff, lint, etc., in your tension areas.
Posted on Mar 12, 2011
Hello! I have a problem with my Brother LS-1717p sewing machine. The needle keeps becoming unthreaded. The bobbin seems to be correctly threaded and comes out to the fabric. When I push the pedal the 2...
So the un derside of the item being sewn looks more like a **** rug? It's either the bobbin is wound in the wrong direction, put in the bobbin chamber wrong and needs to flipped over or the thread in the needle needs to be threaded in a different direction. Try each of these one at a time to see which one is the culpret! I doubt it's the thread tension. When you figure it out, write it down and put the answer in the under storage area of the machine for future reference! Hope this helps!
Sep 22, 2011 | Vacuums
Excessive thread under fabric...jams up the machine. Have rethreaded, replaced needle, rewound bobbin...no difference. Sews a few stitches then under thread just gets jammed in machine. Viking 1100.
So the underside looks more like a **** rug? 2 things to try. The problem is the bobbin. try flipping the bobbin over (take it out, turn it over and put it back in). The writing on the bobbin printed in the plastic should be on the top and no writing on the underside. 2nd,make sure it's threaded front to back and not looped around the needle. I have the same machine~it did that too!
Sep 05, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I have a Tacsew T11-115 and I do not have an instruction book. I need to see if I have it treaded correctly and how to adjust the bobbin tension. The top thread is laying on the fabric and the bobbin...
For all sewing machines, if the bobbin thread is showing on the top surface, then the top tension is probably too tight. Turn the tension indicator to the left by half a number to a lower value. (So that if 5 was lined up with the dot initially, then go to 4.5 lined up with the dot).
See this article for some clear pictures of thread tension adjustments: http://www.ca.uky.edu/HES/fcs/FACTSHTS/CT-MMB-213.pdf . If you can find it the Singer Sewing Book is a good reference http://www.amazon.com/Singer-Sewing-Book-Gladys-Cunningham/dp/0307098702 .
This site, http://www.allbrands.com/products/abc0762.html , may be able to find and send you a manual to the TacSew T11-115. They have the T11-155 for sale.
I hope this helps.
Jun 12, 2011 | Vacuums
I have a Janome 8048. Here's my problem: As I sew I notice that the stitches on the top of the fabric look the way they should on the bottom side and when I take the material off the machine and flip it...
I haven't sewn in years. A sewing machine has a tension control on top and on the bobbin. If the intersection of the top and bottom threads is not in the middle of the sewn material, you have to adjust your tension.
In your case, what I think you are saying is that the stitch on top is just a straight line and on the back it disappears into the fabric.
To correct this, lower the top tension by loosening the tension adjuster on the thread where the thread loops around the small pulley.
Also, you could tighten the tension on the bobbin by slightly tightening the small screw on the side of the bobbin.
Gary
Feb 21, 2011 | Vacuums
The stiches are looping on the underside of fabric.I have tightened the top tension to its maximum.I have the correct sized needle, the machine has been oiled and it is threaded correctly. What else can I...
There is an adjustment on the bobbin holder - the little screw on the plate. Make sure that the bobbin is tightly wound and that it is correctly inserted, the thread must double back on itself coming out of the holder.
Feb 19, 2011 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
