Question about Car Audio & Video
How do I find a driver board 02-01596-01 or amplifier assembly for TLX PS12 Sub Woofer is OK Oshawa,Ont.Canada many thanks
  • 6 Answers
SOURCE: Amplifier
What is the RMS on the Sub?
Posted on Sep 30, 2007
  • 4234 Answers
SOURCE: Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Posted on Apr 08, 2008
  • 631 Answers
SOURCE: AMPLIFIER NOT WORKING
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Aug 20, 2008
  • 1126 Answers
SOURCE: Ohm calculations; 4 and 8 ohm sub woofer?
+ output from amp to + input of 4 ohm to + input of 8 ohm AND - output from amp to - input of 4 ohm to - input of 8 ohm is a parallel circuit = 2.66 ohm impedance load for amp
+ output from amp to + on 4 ohm - on 4 ohm to + on 8 ohm - on 8 ohm to - of power amp is a series circuit = 12 ohm impedance load for amp. Clear as mud??
Clear as mud?
Posted on Jun 11, 2009
  • 1138 Answers
SOURCE: run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Posted on Jun 23, 2009
Can i wire non amplified mid-range/tweeter speaker's on the inside of an altec acs250 sub woofer directly to the woofer speaker
Probably not. Somewhere there is a filter (crossover) that only sends the lower frequencies to the sub-woofer driver. Where that filter resides (either in the pre-amp, receiver or sub-woofer enclosure is yet to be known).
Oct 27, 2016 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
How many total watts
Hello
The power rating for this amp is as follows.
Two channel: Sub woofer: Min 35Watts
Two channel: Other than sub woofer : 70Watts
One channel: sub woofer; 100Watts
One channel: other than sub woofer: 200Watts.
OK.
Dec 17, 2011 | Pioneer GM-X332 Car Audio Amplifier
I have a JBL TLX PS10 sub woofer, and it keeps blowing fuses almost immediately.What do you think the most likely problem is? also, where can I download a free service manual for this item? I have removed...
Edwards Electronics not only repairs the following amps they also do upgrades to them so they do not burn up again: TSS1100 TSS1200 PS10 PS12 E250P PS210 and a few others - Look on Google for them or Ebay. Thanks.
Aug 17, 2011 | JBL TLX PS10 Speaker
Transformer is not providing power to timer unit, power bulb is indictaing off power on screen. Have completly powered down and powered up. Model - pocket star 4 zone Thanks Dan...
The transformer is seams to be working, the power bulb indicator working tells me that the transformer is ok. You may need to check the circuit
board.
Jun 04, 2011 | Orbit Sprinkler System Power Source...
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | Audio Players & Recorders
1211a amplifier
if your amp. work in bridge you can attach + 1st channel and + 2st channel to your sub woofer. by series 2 ohm you have 4 ohm sub woofer.
Sep 26, 2008 | Infinity Reference 1211a Car Audio...
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
