Question about Tascam Dp-02cf Digital 8-track Recorder
I made and saved a master of a song, now i want to tweak it a bit but i'm not sure how to get rid of the current master. because it's saved i cannot do another. Help??
  • 3 Answers
Play the original song back. not the master, but the original song. tweak all you want and then master it again, the new master will replace the old one automatically.
Posted on Dec 30, 2012
Downloaded new version of itunes now i cant burn cds
you have to set the process up again Burning CDs in iTunes is easy and requires no setup.
But if you are an advanced user, you may want to tweak the settings a bit. Here's how you can set CD burning preferences in iTunes:
Open up iTunes on your computer. Click Edit and then select Preferences. Click the Advanced tab. Click the Burning tab within the Advanced tab. Set your preferred speed. From the drop-down menu, choose a burn speed for your CD burner. Choose a format. Audio CDs are for playing in your stereo or CD player. MP3 CDs can hold more songs, but need a special type of CD player to be read. Data CDs are for backing up songs, and can only be read by computers. Choose a gap between songs. By default, iTunes puts a gap of silence between each song. You can change this option from the drop-down menu. Use the Sound Check feature. This option will automatically adjust the volume on your songs so they will be the same volume on the CD. Include the CD text option. This will give the CD the title of the playlist to be displayed by a stereo or CD player that supports CD text. Click OK to save your preferences.
Feb 18, 2013 | Dell Inspiron Zino HD Desktop Computer...
Downoaded i tunes now i cant burn cds
you might have to set the process up again
Burning CDs in iTunes is easy and requires no setup. But if you are an advanced user, you may want to tweak the settings a bit. Here's how you can set CD burning preferences in iTunes:
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
What jailbreak appsdrain your battery faster?
In general, a little bit yes. But there are simple solution such as SBsettings(jailbreak tweak) that will help you change the brightness easier so you can turn the brightness down and save battery. Also, if it is an iPhone there is a tweak (Auto 3g) that will switch the 3g and Edge radio to save battery. The jailbreak apps won't usually drain the battery, its the jailbreak themes and such but it is easy to save battery.
Apr 16, 2011 | iPhone Apps
MY LIFT MASTER 1245 IS HUMMING AND GARAGE DOOR STOP HALF WAY DOWN LIGHT BLINKS
If the main light is blinking 10 times check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Jan 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
How do you creait a playlist
You must first Rip your albums or Mix CD's to your Xbox, insert an album and click on Rip CD to save it to your Hard Drive, play an album and click on edit or save playlist below the play/stop/forward/ buttons, and get rid of songs you don't want if needed. While playing that album still, back out with the red "b" button on your controller and back up until you are back at albums, now click on it, select another album, and choose "add to current playlist" or "add to playlist" and it will now stack that album on the bottom of the first. Again you can edit and delete or organize songs, then save playlist. Now you can name it and when you go to saved playlists instead of Albums, it will be there. Anymore trouble, please email me at xxsodasipperxx@yahoo.com
Jul 09, 2010 | Microsoft Xbox 360 Console
Ikeep getting an error message when i go to mixdown/matering.it says that my tracks are too short,change outpoint. How do I change outpoint and to what do i change it to?Song is 4 mins. 23 secs long.
The 2488 requires a start point and end point in order to master down. The start point, by default is zero (the beginning of the song) so you will NOT have to create one, HOWEVER, you MUST provide an end point. The end point is wherever you wish the song to end, so, roll the BIG wheel to the end of the song, then, press LOCATE SET and OUT simultaneously. You have just now marked your out point and thus it will master the whole song. NOTE: If your song is 4:23, then the out point will be/should be a bit longer (a second or two- or even more- that's up to you) than that depending on where the song/music actually begins after the zero mark, therefore, make SURE you roll the BIG wheel enough to encompass the WHOLE SONG. The counter will reflect the time/length as a result of how far you roll the wheel. I hope this helps. One last note, do ALL this at the MIXDOWN prior to MASTERING.
Feb 22, 2010 | Tascam 2488 Portastudio Multitrack...
Transferring songs onto new CF card
You'll have to create backups of your songs and transfer those backups using USB to your PC. Then with the 8 GB card inserted you can reimport them to the Tascam (USB) and restore them to the current working song which will then get saved on your 8 GB card. Do this for each song and then you can discard (delete) those backed up song files while connected to the PC.
Hope this helps.
bd.
Feb 07, 2009 | Tascam 2488 Portastudio Multitrack...
Unable to save sounds
try master clear or master reset or have it reprogrammed
Jan 06, 2008 | Motorola Mobility RAZR V3
Tascam Dp-02cf Digital 8-track Recorder Logo
65 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
