Question about Car Audio & Video
Hi. i have rattler 300 car alarm i lost the remote bought one on ebay rpn471t but dont know how to program it can you guys help me?
  • 46 Answers
SOURCE: Programming keyless remote for Neon 2004
There is a way to program a remote if there is already a valid remote. Unfortunatly if you don't have a valid remote the only way to get one programmed is at the dealership with their scan tool.
I have pasted directions for programming a remote if there is already a valid transmiter.
CUSTOMER PROGRAMMING For a customer to be able to program RKE transmitters themselves, at least one RKE transmitter must be programmed already. This procedure is to add additional transmitters. If all transmitters are lost, the DRB III® scan tool must be used to program the new transmitters.
  1. Insert the key into the ignition switch, and turn the ignition switch to the RUN position without starting the vehicle (allow chimes to stop).
  2. Using the RKE transmitter programmed to the RKE module, press and continuously hold down the UNLOCK button for 4-10 seconds.
  3. Within the 4-10 second time range, continue to hold the UNLOCK button and press the PANIC button. Both buttons may then be released. Upon the PANIC button being depressed, the message for customer programming mode will be transmitted to the RKE module.
  4. A chime will be heard to verify that the customer programming mode has been entered (allow 3 seconds to hear chimes).
  5. Press and release any button on each transmitter that is to be programmed to the RKE module, including any transmitters which were previously programmed to the RKE module (with a maximum of four possible). After each transmitter is successfully programmed, a chime will be heard to verify that successful programming of the transmitter has occurred.
  6. After thirty seconds, or upon the ignition switch being turned OFF, the RKE module will exit programming mode.
Posted on Aug 30, 2008
  • 33 Answers
SOURCE: HOW DO I DISARM RATTLER ALARM ON MY SATURN L100 IT
This car does not come with that equipment as factory option. You may wish to put the alarm in "valet" mode. There should be an override/valet button or switch mounted somewhere under the lower dash panel. With the key in the "run" position, push the valet button, and the little red "LED" light should light solid, verifying it's in valet mode, and will not arm, but keyless entry functions will still work.
Posted on May 06, 2009
  • 87 Answers
SOURCE: I NEED PROGRAMING INSTRUCTIONS PLEASE!
Copy and paste or click - then program!
http://www.directed.com/guides/manuals/og/viper/429V.pdf
Posted on Jun 02, 2009
SOURCE: programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Posted on Jun 09, 2009
Molson02536
  • 3854 Answers
SOURCE: programing instructions for buick 2006 lacrossekeyless remote fob
Transmitter ProgrammingImportant: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool. Important: The scan tool must stay connected until all of the transmitters are programmed.
  4. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  5. Repeat the previous step in order to program up to 4 transmitters.
  6. Remove the scan tool.
  7. Operate the transmitter functions in order to verify correct system operation.
Good luck
Posted on Dec 13, 2009
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
Oct 27, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm(car) when replace batt(car)alarm goes off like crazy
should be able to close everything on car and just hit the unlock button should disarm if not you may have to hold the valet switch to reet
May 10, 2012 | Nissan Vehicle Parts & Accessories
I have lost my lexus remote control key. how and where can i buy a new one through the net. thank you..
Buy it from :-
http://cgi.ebay.com/ebaymotors/2001-2002-2003-LEXUS-RX-300-RX300-KEY-REMOTE-KEY-_W0QQcmdZViewItemQQitemZ120607853494QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I hope i have been helpful.
Thank You!!
Aug 21, 2010 | 2001 Lexus RX 300
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
No instructions for installing car alarm
hello guys i bought a nitro 422bmw 2-way alarm system and i didnt get the manuanl for this alarm system , the code for the this alarm system? can you please help with this solution? my name is joey? thank you guys
Jul 29, 2009 | Scytek 2000RS Remote Control
HOW DO I DISARM RATTLER ALARM ON MY SATURN L100 IT WONT START SOMETIMES LIGHT KEEPS FLASHING INSIDE I JUST BOUGHT CAR USED 56000MILESD ON IT ITS DRIVING ME CRAZY I DONT KNOW IF IS FACTORY OR NOT
May 05, 2009 | Vehicle Parts & Accessories
REMOTE DOOR LOCK 1997 ES 300 LEXUS
Even if the remote is fairly new they can lose their programming you may have to have it re-programed
Mar 17, 2009 | 1997 Lexus ES 300
1996 Grand Cherokee keyless entry problem
That remote should not be able to  be programmed by you, it needs to be programmed by the dealer using their computer.  I know that some later and earlier models can be programmed by the user, but I did some research on this as i have a 96 as well and it seems the 96 was a dealer computer thing.  If you in fact bought the remote from the dealer they should be willing to program it for FREE.  Otherwise I was given a $30 estimate for the programming.
Dec 07, 2008 | 1996 Jeep Grand Cherokee
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
