Question about Montgomery Ward Refrigerators
I need a wiring diagram for hmg194647a to replace the electric cord.
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
  • 2468 Answers
SOURCE: Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: need wire diagram for 4 wire cord [color code[...
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on May 20, 2010
katshelpnya
  • 17 Answers
SOURCE: need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Posted on Feb 01, 2011
SOURCE: When replacing cord on black & decker 7190
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Posted on Jun 03, 2011
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
http://www.greenworkstools.com/uploads/documents/51012_1700PSI_Pressure_Washer_E_Manual.pdf
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
Put on a new power cord wiring diagram
If you need a wiring diagram for this task you should not be doing the work. Please don't dis-assemble the fan, or try to work on it unless you already know what you are doing, you could easily use the wrong cord or not connect the (rather simple I admit) wires correctly.
Feb 07, 2015 | Dryers
How to replace a porwer cord for bissell 68c71
Cut cord at base. Strip wires. Buy a new cord. Rewire.
Apr 23, 2014 | Vacuums
How to rewire a GE 75423 electric fan
Four wires coming from base to motor. I need a diagram of which wires connect to the electrical components in the base.
Aug 26, 2012 | Dryers
Need wiring diagram for electric cord attachment
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Feb 07, 2010 | Kenmore 62602 Electric Dryer
How to replace a cord?
just open up the area where the electric cord is attached and make a diagram of which colors go where. Then remove one wire and reinstall one wire at a time.
Mar 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
WIRING DIAGRAM
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Refrigerators Logo
20 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
john h
ray gallant
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
