Question about Tefal Ultraglide 1549 Iron
Tefal pro express steam generator model 2929 no longer generating steam - don't hear pump working - iron gets hot but not transfering water
There's 2 possibility:
1- electonic board is defectuose 2- pump is defetuose
Posted on Sep 13, 2011
Tefal pro express steam generator iron. When in use the handle gets really hot. I have to put a cloth around it to use. Help.
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Oct 23, 2017 | Tefal Irons
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Irons
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Tefal Ultraglide 1549 Iron Logo
2,120 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
